DEM-311GTEOL EOS
Mini GBIC moodul 1000Base-SX pordiga multimood optilise kaabli jaoks, toide 3,3 V (kuni 550 m)
Kirjeldus
Modules D-Link SFP transceivers represent a connection to Gigabit Ethernet switches or switches 10/100 Mbit / s , equipped with a slot SFP, to the networks of Gigabit Ethernet. SFP modules provide a flexible and simple solution for high-speed network connection Gigabit Ethernet. Depending on the type of fiber optic cable to a switch you can set the desired module SFP. Optical transceivers are equipped with standard LC connectors for compatibility .
Size Small Form Pluggable (SFP)
These transceivers are sized in accordance with industry-standard Small Form Pluggable (SFP). The modules are inserted into the slot SFP Switch Gigabit Ethernet. They provide the necessary signal amplification for the transmission and reception of data when a port is connected to an optical or copper cable .
Hot-swappable
All modules SFP D-Link support hot-swappable . You can remove or replace the SFP, without turning off the switch. This feature allows you to add or change SFP modules without having to stop your network.
Application
The use of optical modules GBIC: distributed processing and storage of data , cascaded switches Gigabit Ethernet, high-speed reading and writing files , increasing the capacity of the network segment increased distance data transmission channel.
Põhiomadused
Multimood optiline transiiver (550 m)
DEM-311GT
  • 1000BASE-SX port (IEEE 802.3z standart)
  • Dupleks LC ühenduspistik
  • Täisdupleksrežiim
  • Voojuhtimine 802.3x
  • Kaabli tüüp: multimood optiline kaabel 50 või 62.5 µm, kuni 550 m
  • Lainepikkus: 850 nm
  • Toide: 3.3 V
  • Käigultvahetus (hot swapping)
  • Laser klass 1 vastavalt EN 60825-1
  • TTL signaali tuvastamise indikaator
Sertifikaadid
Sidustooted
MiniGBIC moodulid
DEM-310GT - 1000BASE-LX, monomood optiline kaabel, max 10 km
DEM-311GT - 1000BASE-SX, multimood optiline kaabel, max 550 m
Pildid
DEM-311GT/C
Eestvaade
Failid
Vaadake samuti
