DGS-3700-12EOL EOS
Hallatav 2.kihi kommutaator, 8 x 10/100/1000Base-T porti + 4 kombo porti 1000Base-T/Mini GBIC (SFP)
Kirjeldus
D-Link DGS-3700 series Metro Switches are designed & purpose-built for Metro Ethernet services for Telecom/Service Providers. Its design is based on feld proven experience learnt from multiple Ethernet deployment in Telecoms/Carriers. It  supports wide variety of technologies including Ethernet, OAM (Operations,  Administration  and  Maintenance), Double VLAN (Q-in-Q), QoS and Triple play services demanded by Carrier Ethernet networks.
Product Overview
D-Link DGS-3700 series is D-Link Metro switch family optimized  for  the  Ethernet-to-the-Home  (ETTH)  and Ethernet-to-the-Business  (ETTB)  services.  It  comes ready with Service Provider-Friendly hardware, robust software  &  security  features,  OAM  manageability functions and Triple-Play Services.
D-Link DGS-3700 series comes with:
- D-Link DGS-3700-12 with 8-Port 10/100/1000Mbps +  4 Combo Copper/SFP L2 Management Switch
- D-Link DGS-3700-12G 8-Port SFP + 4 Combo Copper/SFP L2 Management Switch
The SFP Gigabit ports support a wide variety of SFP tranceivers.  They  include  100Base-FX,  1000Base-LX,  1000Base-SX,  1000BASE-SXM,  1000BASE-LHX, 1000BASE-ZX  and Wavelength-Division Multiplexing (WDM) SFP transceivers.
Service Provider-Friendly Hardware
D-Link DGS-3700 series is designed to be deployed in compact and outdoor Telecom/Carriers cabinet. It has a compact  form  factor of  210 mm  in depth  in a  1U  rack  enclosure with  operating  temperature  of up  to 65?C. Furthermore,  to simplify feld  installation, troubleshooting  and  maintenance,  it  has  all  the access connection located on the front panel.
These include:
- 10/100/1000Base-T Ports or SFP Slots
- Modular AC/DC Power Supply
- Modular Fan
- Modular Dust Filter
- RS-232 console port
- RJ-45 OOB management port
- RJ-45 Alarm port
- Grounding
Robust Software & Security
D-Link  DGS-3700  series  provides  extensive  VLAN support  including  Double  VLAN  (Q-in-Q),  Layer 2 Protocol  Tunneling  (L2PT),  GARP/GVRP  and  802.1Q to  enhance  network  security  and  performance. Bandwidth Control can be fexibly  set  for each port using pre-defned  thresholds  to assure a committed level  of  service  for  end  users.  For  advanced applications,  per-fow  bandwidth  control  allows easy  fne-tuning  of  service  types  based  on  specifc IP addresses or protocols. Moreover,  it has a robust set  of  multi-layer  (L2,  L3,  L4)  QoS/CoS  features optimized  for Triple-Play Services  like Voice over  IP (VoIP), Media-on-Demand (MOD), Intranet and video conferencing. Priority queues for 802.1p/TOS/DiffServ are supported, with classifcation and marking based on  MAC  SA/DA,  IP  SA/DA,  and/or  TCP/UDP  port numbers.
D-Link  DGS-3700  series  provides  a  complete  set  of security features, which include IP-MAC-Port Binding (IMPB)  with  DHCP  Snooping,  L2/L3/L4  multi-layer Access Control Lists and 802.1X user authentication via TACACS+ and RADIUS servers. In addition, it also offers  supression  capabilities  to  enhance  network performance  and  security.  To  prevent  malicious fooding  traffc caused by worm/virus  infections,  the DGS-3700  series  in-built Safeguard Engine enforces its reliability, serviceability and availability.
OAM Management
To uphold enterprise customers’ SLA, service providers must reduce the Mean Time to Repair (MTTR) and increase service availability. Ethernet OAM  features address these challenges and enable service providers to offer carrier-grade services. D-Link DGS-3700 series supports industry-standard OAM  tools including IEEE 802.1ag Connectivity Fault Management and IEEE802.3ah Ethernet in the First Mile. IEEE 802.1ag protocol provide tools to monitor and troubleshoot end-to-end Ethernet networks allow service providers to check connectivity, isolate network issues, and identify customers affected by network issues. IEEE 802.3ah Ethernet in the First Mile protocol provides OAM discovery, local and remote loopback diagnostic on the link between the  customers’ equipment and the service provider network.
Põhiomadused
Interface
+ 8 10/100/1000BASE-T Ports
+ 4 Combo 10/100/1000BASE-T/SFP  Ports
+ 1 RS-232 Console Port
+ 1 RJ-45 OOB management port
+ 1 RJ-45 Alarm port
Modular Components
+ Dust Filter
+ Fan
+ Power supply unit (AC & DC)
Performance
+ Switch Fabric: 24Gbps
+ Packet Forwarding Rate 17.86Mpps
+ Packet Buffer 1MB
+ MAC Address Table 16K Entries
+ Jumbo Frame Size 13,312 Bytes
L2 Features
+ Virtual Stacking
+ MAC Address Table: 16K
+ Flow Control:
  - 802.3x Flow Control
  - HOL Blocking Prevention
+ Jumbo Frame up to 13,312 Bytes
+ Spanning Tree:
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - BPDU Filtering
  - Root Restriction
+ Loopback Detection
+ 802.3ad Link Aggregation
  - Max. 6 groups per device / 8 Gigabit ports per group
+ Port Mirroring:
  - One-to-One
  - Many-to-One
  - Flow-based Mirroring
  - RSPAN mirroring*
+ E-RPS* (Ethernet Ring Protection Switching)
+ L2 Protocol Tunneling
L2 Multicasting
+ IGMP Snooping:
  - IGMP v1/v2/v3 Snooping
  - Support 1K IGMP Groups
  - IGMP Snooping Fast Leave
  - Host-based IGMP Fast Leave
+ IGMP/MLD Proxy Reporting
+ IGMP/MLD Filtering
  - Up to 60 IGMP fltering profles, 128 ranges per profle
+ MLD Snooping:
  - MLD v1 Snooping
  - MLD v2 Snooping*
  - Support 1K MLD snooping Groups
  - MLD Snooping Fast Leave
VLAN
+ VLAN Group:
  - Max. 4K Static VLAN Groups
  - Max. 2K Dynamic VLAN Groups
+ 802.1Q Tagged VLAN
+ 802.1v Protocol VLAN
+ GVRP
+ Double VLAN (Q-in-Q):
  - Port-Based Q-in-Q
  - Selective Q-in-Q
+ Voice VLAN*
+ MAC-Based VLAN
+ Guest VLAN
QoS
+ 802.1p Quality of Service
+ 8 Queues
+ CoS Based on:
  - Switch Port
  - VLAN ID
  - 802.1p Priority Queues
  - MAC Address
  - IPv4/v6 Address
  - DSCP
  - Protocol Type
  - IPv6 Traffc Class
  - IPv6 Flow Label
  - TCP/UDP Port
  - User-Defned Packet Content
+ Three Color Marker
  - trTCM
  - srTCM
+ Congestion Control:
  - SRED
+ Support following Actions for Flows
  - Remark 802.1p Priority Tag
  - Remark TOS/DSCP Tag
  - Bandwidth Control
  - Flow Statistics
  - Committed Information Rate(CIR), min. granularity 64Kbps
+ Bandwidth Control:
  - Port Based (Ingress/Egress, Min. Granularity 64Kbps)
  - Flow Based(Ingress/Egress, Min. Granularity 64Kbps)
ACL (Access Control List)
+ Up to 1,500 access rules
+ ACL Based on:
  - 802.1p Priority
  - VLAN ID
  - MAC Address
  - Ether Type
  - IPv4/v6 Address
  - DSCP
  - Protocol Type
  - TCP/UDP Port Number
  - IPv6 Traffc Class
  - IPv6 Flow Label
  - User Defned Packet Content
+ Time Based ACL
+ CPU Interface Filtering
+ ACL Statistic
Security
+ SSH v1/v2
+ SSL v1/v2/v3
+ Port Security up to 128 MAC address per port/VLAN
+ Broadcast/Multicast/Unicast Storm Control
+ Traffc Segmentation
+ IP-MAC-Port Binding:
  - Supports 500 Address Binding Entries per Device
  - Supports ARP / ACL / Auto (DHCP Snooping) Mode
+ D-Link Safeguard Engine
+ ARP Spoofng Prevention*
+ DHCP Server Screening
+ DHCP Client Filtering
+ BPDU Attack Protection*
+ NetBIOS/NetBEUI Filtering
AAA
+ 802.1X:
  - Port-Based Access Control
  - Host-Based Access Control
  - Dynamic VLAN Assignment
+ Web-Based Access Control (WAC):
  - Host-Based Access Control*
+ MAC-Based Access Control (MAC):
+ Microsoft® NAP (Support IPv4/v6)
+ RADIUS and TACACS+ authentication for switch access
+ 3 Level User Account
+ RADIUS Accounting
Operation, Administration & Management (OAM)
+ Loopback Diagnostic
+ Cable Diagnostic
+ 802.1ag Connectivity Fault Management (CFM)
  - Support 64 MIPs & 32 MEPs
+ 802.3ah
+ ITU-T Y.1731*
+ Optical Transceiver Digital Diagnostic Monitoring (DDM)
Management
+ Web-Based GUI (Support IPv4/v6)
+ Command Line Interface (CLI)
+ Telnet Server (Support IPv4/v6)
+ Telnet Client (Support IPv4/v6)*
+ TFTP Client (Support IPv4/v6)
+ XModem
+ ZModem
+ SNMP v1/v2c/v3
+ SNMP Traps
+ System Log
+ RMON v1
  - Support 1,2,3,9 Groups
+ RMON v2
  - Support ProbeConfg Group
+ sFlow
+ LLDP
+ LLDP-MED*
+ IPv6 Neighbor Discover (ND)
+ BootP/DHCP Client
+ DHCP Auto-Confguration
+ DHCP Relay Option 60
+ DHCP Relay Option 61
+ DHCP Relay Option 82
+ DHCP Server*
+ DNS Relay*
+ DNS Client*
+ Flash File System*
+ Dual Image
+ Dual Confguration
+ CPU Monitoring
+ Cable Diagnostic
+ SNTP
D-Link Green
+ Comply with RoHS 6
+ Power Saving Mode*
  - Link Down Status
MIB
+ RFC1155, 2578 MIB Structure
+ RFC1212 MIB Defnition
+ RFC1213 MIBII
+ RFC1493 Bridge MIB
+ RFC1901 ~ 1908 SNMPv2 MIB
+ RFC1757, 2819 RMON MIB
+ RFC2021 RMONv2 MIB
+ RFC1643, 2358, 2665 Ether-like MIB
+ RFC 2668 802.3 MAU MIB*
+ RFC2674 Q-Bridge/P-Bridge MIB
+ RFC2674 802.1p MIB
+ RFC2233, 2863 IF MIB
+ RFC2618 RADIUS Authentication Client MIB
+ IGMPv3 MIB
+ RFC4022 MIB for TCP
+ RFC4113 MIB for UDP
+ RFC3298 MIB for Diffserv
+ RFC2620 RADIUS Accounting Client MIB
+ Ping MIB
+ Traceroute MIB*
+ Running Confguration MIB
+ TFTP Upload/Download MIB
+ DDM MIB
+ RFC2465 IPv6 MIB
+ RFC2466 ICMPv6 MIB
+ RFC4292 IP FDB MIB
+ RFC4293 IPv6 SNMP Mgmt Interface MIB
+ D-Link Private MIB
Standard Compliance
+ RFC768 UDP
+ RFC791 IP
+ RFC792 ICMPv4
+ RFC2463 ICMPv6
+ RFC4884 Extended ICMP
+ RFC793 TCP
+ RFC826 ARP
RFC1981 Path MTU Discovery for IPv6
+ RFC2460 IPv6
+ RFC2461, 4861 IPv6 ND
+ RFC2462 IPv6 Stateless Address
  - Auto-confguration
+ RFC2464 IPv6 over Ethernet and Defnition
+ RFC4291 IPv6 Addressing Architecture
+ RFC4213 IPv4/IPv6 Dual Stack
+ RFC2474, 3168, 3260 IPv6 Differentiated Services Field
*Function available in future frmware upgrade
Sertifikaadid
Sidustooted
DGS-3700-12  Hallatav Gigabit Ethernet 2.kihi kommutaator Metro Ethernet võrkude jaoks
Võrguhaldustarkvara
DV-600S    Võrguhaldustakrvara D-View 6.0 (standartne versioon)
DV-600P    Võrguhaldustarkvara D-View 6.0 (professionaalne versioon)
Lisa SFP-transiiverid
DEM-310GT    SFP-transiiver, 1000BASE-LX, monomood optiline kiud, maksimaalne vahekaugus kuni 10 km, tööpinge 3,3 V
DEM-311GT
SFP-transiiver, 1000BASE-SX, multimood optiline kiud, maksimaalne vahekaugus kuni 500 m, tööpinge 3,3 V
DEM-312GT2
SFP-transiiver, 1000BASE-SX, multimood optiline kiud, maksimaalne vahekaugus kuni 2 km, tööpinge 3,3 V
DEM-314GT
SFP-transiiver, 1000BASE-LH, monomood optiline kiud, maksimaalne vahekaugus kuni 50 km, tööpinge 3,3 V
DEM-315GT
SFP-transiiver, 1000BASE-ZX, monomood optiline kiud, maksimaalne vahekaugus kuni 80 km, tööpinge 3,3 V
DEM-330T
WDM SFP-transiiver, 1000BASE-BX, monomood optiline kiud, maksimaalne vahekaugus kuni 10 km, tööpinge 3,3 V (Tx 1550 nm, Rx 1310 nm)
DEM-330R
WDM SFP-transiiver, 1000BASE-BX, monomood optiline kiud, maksimaalne vahekaugus kuni 10 km, tööpinge 3,3 V (Tx 1310 nm, Rx 1550 nm)
DEM-331T
WDM SFP-transiiver, 1000BASE-BX, monomood optiline kiud, maksimaalne vahekaugus kuni 40 km, tööpinge 3,3 V (Tx 1550 nm, Rx 1310 nm)
DEM-331R
WDM SFP-transiiver1000BASE-BX, monomood optiline kiud, maksimaalne vahekaugus kuni 40 km, tööpinge 3,3 V (Tx 1310 nm, Rx 1550 nm)
DEM-211
SFP-transiiver, 100BASE-FX, multimood optiline kiud,  maksimaalne vahekaugus kuni 2 km, tööpinge 3,3 V
DEM-210
SFP-transiiver, 100BASE-FX, monomood optiline kiud, maksimaalne vahekaugus kuni 15 km, tööpinge 3,3 V
DEM-220T
WDM SFP-transiiver, 100BASE-BX, monomood optiline kiud, maksimaalne vahekaugus kuni 20 km, tööpinge 3,3 V (Tx 1550 nm, Rx 1310 nm)
DEM-220R
WDM SFP-transiiver, 100BASE-BX, monomood optiline kiud, maksimaalne vahekaugus kuni 20 km, tööpinge 3,3 V (Rx 1550 nm, Tx 1310 nm)
Pildid
DGS-3700-12
Eestvaade
Tagantvaade
Failid
Vaadake samuti
