Kiirotsing
Toote omadused:
8-Port Gigabit Switch
EOL
Kirjeldus:
Effortless Gigabit Networking
With data transfer speeds of up to 2000Mbps on Gigabit Ethernet, the D-Link DGS-1008D 8-Port Gigabit Switch is ideal for transfering files quickly and online gaming. The DGS-1008D features front, easy-to-access Ethernet ports with two color LED indicators per port to easily distinguish link status. The switch features QoS, which organizes and prioritizes time-sensitive and important data for efficient delivery, allowing for smooth streaming media, VoIP calling, and online gaming. Additionally the switch features a Kensington Security Slot on the rear panel where users can fasten the unit to a table or desk.
Think Green
The DGS-1008D is a plug-and-play networking switch that features D-Link’s Green Technology to save energy and reduce heat, which in turn extends product life without sacrificing performance or functionality. The switch supports IEEE 802.3az Energy-Efficient Ethernet (EEE) which can detect when a connected computer is shut down or when there is no Ethernet traffic, and will proceed to power down the idle port, saving a substantial amount of power. In addition, the switch can also save energy by detecting the length of cable connected to a port and use only as much power as is required. Both of these features work together to help you save power automatically.
Environmentally Friendly
The switch was designed with the environment in mind. It is compliant with Energy Star Level V, CEC, and MEPS regulations which require the use of energy efficient power adapters. The switch is built to comply with RoHS standards to minimize use of hazardous materials and is packaged with an Energy Star Level V qualified power adapter in a recyclable packaging making this product truly environmental friendly.
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
