Kiirotsing
Toote omadused:
SFP Transceiver 1 Port 1000Base-BX for singlemode fiber optic cable, power supply 3.3V (up to 2km), WDM (TX: 1310nm, RX: 1510nm)
Põhiomadused:
Standard
Standard Compliance
IEEE-802.3z, 1000BASE-LX
Form Factor Type
SFP
Fiber Media Support
Single-Mode
Distance Capacity
2km
Features
Hot Pluggable
MSA Compliant
RoHS Compliant
Speed
1Gbps
Connector
Simplex LC Connector
Single/Bi-Directional
Bi-directional
Wavelength
TX: 1310nm, RX: 1550nm
Output Optical Power (TX Optical Power)
Max.: -3dBm
Min.: -10dBm
Input Optical Power (RX Optical Power)
Max.: -3dBm
Min.: -21dBm
Sensitivity
-21dBm
Cable Type
Single-mode 9/125 um fiber, reach: 2km
Füüsilised parameetrid
Power
3.3V
Maximum Input Current
3.3V: 300mA
Minimum Power Budget
11dB
Maximum Power Budget
18dB
Heat Generated
1,782kJ/h
MTBF (hours)
213,222
Operating temperature
0 to 70°C
Storage temperature
-40 to 85 °C
Operating humidity
5 to 95%
Storage humidity
5 to 95%
Dimensions
13.5 x 56.6 x 8.5mm
Weight
21g
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
