DGS-1008D/I2EOL EOS
Unmanaged 8-Port Gigabit Switch
Kirjeldus
Think Green
The D-Link 8-Port Gigabit Switch is part of D-Link’s new series of SOHO devices that make use of D-Link’s Green technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. An energy-efficient power adapter (EnergyStar Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
Conserve energy
The DGS-1008 Switch helps you conserve energy through IEEE802.3az EEE, saving feature automatically puts the switch into a low-power idle state when the switch utilization is zero, allowing you to lower your energy usage and save on your energy costs.
Environmentally friendly
The 8-Port Gigabit Switch was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
Põhiomadused
General
• Built-in D-Link Green technology
• Inexpensive Gigabit Ethernet solution for home/SOHO
• 8 10/100/1000 mbps ports
• 16Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x flow control
• Supports 9,216 Byte Jumbo frames
• IEEE 802.1p QoS (4 queues, Strict Mode)
• Cable diagnostics
• RoHS compliant
• Plug-and-play installation
• Fanless design
Standards
• IEEE 802.1p QoS support
• IEEE 802.3 10Base-T Ethernet (twisted-pair copper)
• IEEE 802.3u 100Base-TX Fast Ethernet (twisted-pair copper)
• IEEE 802.3ab 1000Base-TX Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
Protocol
• CSMA/CD
Data Transfer Rates
• Ethernet:
• 10 mbps (half duplex)
• 20 mbps (full duplex)
• Fast Ethernet:
• 100 mbps (half duplex)
• 200 mbps (full duplex)
• Gigabit Ethernet:
• 2000 mbps (full duplex)
Topology
• Star
Network cables
• 10Base-T:
• UTP CAT 3, 4, 5/5e (100 m max.)
• EIA/TIA-586 100-ohm STP (100 m max.)
• 100Base-TX, 1000Base-T:
• UTP CAT 5/5e (100 m max.)
• EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• Per port: Link/Activity/Speed
• Per device: Power
Transmission method
• Store-and-forward
MAC Address Table
• 8K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14880pps per port
• Fast Ethernet: 148800pps per port
• Gigabit Ethernet: 1488000pps per port
RAM Buffer
• 128KBytes per device
Sertifikaadid
Sidustooted
DGS-1008D/I2 Unmanaged 8-Port Gigabit Switch
