Kiirotsing
Toote omadused:
Unmanaged 8-Port Gigabit Switch
Põhiomadused:
General
• Built-in D-Link Green technology
• Inexpensive Gigabit Ethernet solution for home/SOHO
• 8 10/100/1000 mbps ports
• 16Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x flow control
• Supports 9,216 Byte Jumbo frames
• IEEE 802.1p QoS (4 queues, Strict Mode)
• Cable diagnostics
• RoHS compliant
• Plug-and-play installation
• Fanless design
Standards
• IEEE 802.1p QoS support
• IEEE 802.3 10Base-T Ethernet (twisted-pair copper)
• IEEE 802.3u 100Base-TX Fast Ethernet (twisted-pair copper)
• IEEE 802.3ab 1000Base-TX Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
Protocol
• CSMA/CD
Data Transfer Rates
• Ethernet:
   • 10 mbps (half duplex)
   • 20 mbps (full duplex)
• Fast Ethernet:
   • 100 mbps (half duplex)
   • 200 mbps (full duplex)
• Gigabit Ethernet:
   • 2000 mbps (full duplex)
Topology
• Star
Network cables
• 10Base-T:
   • UTP CAT 3, 4, 5/5e (100 m max.)
   • EIA/TIA-586 100-ohm STP (100 m max.)
• 100Base-TX, 1000Base-T:
   • UTP CAT 5/5e (100 m max.)
   • EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• Per port: Link/Activity/Speed
• Per device: Power
Transmission method
• Store-and-forward
MAC Address Table
• 8K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates
• Ethernet: 14880pps per port
• Fast Ethernet: 148800pps per port
• Gigabit Ethernet: 1488000pps per port
RAM Buffer
• 128KBytes per device
Füüsilised parameetrid
DC Input
• DС 5V/1A, external power supply
Power consumption
• Power on (Standby):
  • AC input: 0.59 watts
  • DC input: 1.5 watts
• Maximum:
  • AC input: 3.48 watts
  • DC input: 5.4 watts
MTBF (hours)
522,270
Operating temperature
• 0 to 50°C
Storage temperature
• -10 to 70°C
Operating humidity
• 10% to 90% rh non-condensing
Storage humidity
• 5% to 90% rh non-condensing
Certifications
• FCC Class B
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• LVD
• CB
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
