Kiirotsing
Toote omadused:
SFP Transceiver 1 Port 10GBASE-LRM (with DDM) for multimode fiber optic cable, power supply 3.3V (up to 200m)
Põhiomadused:
Standard
Standard Compliance
IEEE-802.3ae, IEEE-802.3aq, 10GBASE-ZR
Form Factor Type
SFP+
Fiber Media Support
Single-Mode
Distance Capacity
80 km
Features
Hot Pluggable
MSA Compliant
RoHS Compliant
Speed
10Gbps
Connector
Duplex LC Connector
Single/Bi-Directional
Single Direction
Wavelength
1550nm
Output Optical Power (TX Optical Power)
Max.: 4dBm
Min.: 0dBm
Input Optical Power (RX Optical Power)
Max.: -7dBm
Min.: -24dBm
Sensitivity
-24dBm
Cable Type
Multi-mode 9/125 um fiber
Power
3.3V
Maximum Input Current
450mA
Minimum Power Budget
24dB
Maximum Power Budget
24dB
Heat Generated
5.35kJ/h
MTBF (hours)
1,584,786
DDM (Digital Diagnostics Monitoring)
No
Operating temperature
0 to 70°C
Storage temperature
-40 to 85 °C
Operating humidity
5 to 85%
Storage humidity
5 to 95%
Dimensions
14.8 x 56.5 x 11.85mm (Compliant with SFF8432)
Weight
20g
Bail Latch Color
White
EMI
CE, FCC, VCCI
Safety
UL, TUV
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
