DES-1008P+EOL EOS
8-Port Unmanaged Switch with 8 PoE Ports
Kirjeldus
The DES-1008P+ D-Link 8-Port Unmanaged Switch with 8 PoE Ports enables office users to easily connect and supply power to Power over Ethernet (PoE) devices such as wireless access Points (AP), IP cameras, and IP phones while also allowing more Ethernet devices like computers, printers, and Network Attached Storage (NAS) to be connected to a network. Built with small business users in mind, this compact PoE switch operates quietly, making it ideal for use in virtually any office.
PoE Versatility
The DES-1008P+ features 8 10/100BASE-TX ports that support the IEEE 802.3af/at PoE protocol allowing a multitude of PoE devices to be connected to your network. In IEEE802.3af mode, each of the 8 PoE ports can supply up to 15.4 watts, and in IEEE802.3at mode, each of the 8 PoE ports can supply up to 30 watts, allowing users to attach an IEEE 802.3af/at compliant device to the DES-1008P+ without requiring additional power. This eliminates the need of having to place networking devices within close proximity of a power outlet and minimizes cable clutter in awkward places such as ceilings or walls.
Ease of Use
No configuration is required and installation is quick and easy. Support for Auto-MDI/MDI-X on all ports eliminates the need for crossover cables for connection to another switch or hub. Auto-negotiation on each port senses the link speed of a network device (either 10Mbps or 100Mbps) and intelligently adjusts for compatibility and optimal performance. When an IEEE 802.3af/at compliant device is attached, power supplied to that device will be automatically adjusted to fit the device. The DES-1008P+ also features diagnostic LEDs, which display status and activity, allowing you to quickly detect and correct problems on the network. Combining the versatility of PoE, and ease of use, the D-Link 8-Port Unmanaged Switch with 8 PoE Ports is
the ideal choice for adding PoE devices to a small business network.
Põhiomadused
Standards
IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
ANSI/IEEE 802.3 NWay auto-negotiation
IEEE 802.3x flow control
IEEE 802.3af Power over Ethernet
IEEE 802.3at Power over Ethernet
LAN
IEEE 802.3 10BASE-T
IEEE 802.3u 100BASE-TX compliance
IEEE 802.3x Flow Control support
Data Transfer Rates
Fast Ethernet
100 Mbps Half-Duplex
200 Mbps Full-Duplex
Ethernet
10 Mbps Half-Duplex
20 Mbps Full-Duplex
Functionality
Port Packet Filtering/Forwarding Rate
148,800 pps for 100 M
14,880 pps for 10 M
Switching Fabric
1.6 Gbps switching fabric
Number of Ports
8 10/100 Mbps Fast Ethernet ports
8 PoE ports
Network Cables
10BASE-T:
   • UTP CAT 3/4/5/5e (100 m max.)
   • EIA/TIA-586 100-ohm STP (100 m max.)
100BASE-TX
   • UTP CAT 5/5e (100 m max.)
   • EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
Auto MDI/MDIX adjustment for all ports
LED Indicators
Link/Activity (per port)
Power (per device)
Transmission Method
Store-and-forward
MAC Address Table
2K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates
Ethernet: 14,880 pps per port
Fast Ethernet: 148,800 pps per port
RAM Buffer
96K bytes
Topology
Star
Protocol
CSMA/CD
Physical
Dimensions
280 x 125.8 x 44 mm (11.0 x 5.0 x 1.7 inches)
Weight
1.65 kg (3.63763lbs)
Power Consumption
Power On (Standby, no PD device connected)
  • AC input: 6.9 watts maximum
Maximum: (with 140W PoE device connected)
  • AC input: 146 watts
Heat Dissipation
  • AC input: 22.67 BTU/h
  • AC input: 486.7 BTU/h
MTBF
64,207 hours
Temperature
Operating: 0 to 40 °C (32 to 104 °F)
Storage: -40 to 70 °C
Humidity
Operating: 0% to 95% non-condensing
Storage: 0% to 95% non-condensing
Certifications
FCC
CE
CB
CCC
UL/cUL
Sertifikaadid
Sidustooted
DES-1008P+   8-Port Unmanaged Switch with 8 PoE Ports
Pildid
DES-1008P+/A
Eestvaade
Paremvaade
Tagantvaade
Failid
Vaadake samuti
