Kiirotsing
Toote omadused:
40GBASE-SR4 Multi-mode OM3 (100 m) / OM4 (150 m) QSFP+ Transceiver
Põhiomadused:
Transceiver Type
• QSFP+
Fiber Media support
• Multi-mode
Distance Capacity
• OM3 MMF: 100 m
• OM4 MMF: 150 m
Compliant Standard
• IEEE 802.3ba
Connector
• MPO
Single/Bi Direction
• Single direction
Wavelength
• 850 nm
Output Optical Power (TX)
• Max.: 2.4 dBm
• Min.: -7.6 dBm
Input Optical Power (RX)
• Max.: 2.4 dBm
• Min.: -9.5 dBm
Sensitivity
• -9.5 dBm
Cable Type
• Single 1x12 MPO receptacle (female) with OM3 or OM4 MMF
Supported Features
• Hot Pluggable
• MSA Compliant
• RoHS Compliant
• DDM (Digital Diagnostics Monitoring)
Physical Parameters
Power
• 3.3 V
Max. Input Current
• 350 mA
Min. Power Budget
• 1.9 dB
Max. Power Budget
• 11.9 dB
Heat Generated
• 4.158 KJ/h
MTBF (Hours)
• 4 420 000 hours
Dimensions
• 115.8 mm x 18.4 mm x 13.28 mm
Weight
• 40 g
Operating Temperature
• 0°C to 70°C
Storage Temperature
• -10°C to 75°C
Operating Humidity
• 0% ~ 85%
Storage Humidity
• 0% ~ 85%
Emission (EMI) and Safety Certifications
• FCC Class B
• CE Class B
• VCCI Class B
• FDA/CDRH
• TUV
• CSA
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
