DGS-1024DEOL EOS
24-Port Unmanaged Gigabit Switch
Kirjeldus
The D-Link DGS-1024D 24-Port Unmanaged Gigabit Switch offers an economical way for SOHO and small to medium businesses (SMB) to deploy an energy-efficient switch that features the increased bandwidth of Gigabit ports.
Gigabit on Every Port
The 24-Port Unmanaged Gigabit Switch brings the speed of Gigabit Ethernet to each and every port for a truly high-speed network. If your network has a mix of legacy and modern computing capabilities, each port allows for standard Ethernet, Fast Ethernet, or Gigabit Ethernet connections. You have the latest technology available to every computer and device connected to your network.
Improve Network Efficiency
DGS-1024D 24-Port Unmanaged Gigabit Switch incorporates several optional advanced features to help simplify and improve network management and efficiency. Flow Control throttles connections to ensure connectivity during heavy usage periods by reducing packet loss and wasteful data retransmission. In addition, Storm Control and Port Isolation mitigates the effects of broadcast storms caused by rogue software and malware, which propogate across networks and can bring communication to a standstill.
Innovative Design
The metal case of the DGS-1024D and a compact desktop style helps to generate heat dissipation levels that allow for a fanless design, making the switch silent, as well as economical. The 24-Port Unmanaged Gigabit Switch is small, lightweight, wall-mountable, and ideal for any business with big needs and a small budget.
Think Green
The 24-Port Unmanaged Gigabit Switch helps you to conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save substantial amounts of power by cutting power usage for unused ports or any ports connected to computers that have been shut down.
Conserve Energy
The 24-Port Unmanaged Gigabit Switch features D-Link Green Ethernet technology which provides more energy savings and a longer product life, without sacrificing operational performance or functionality. This environmentally friendly switch is also RoHS compliant, uses recyclable packaging, and minimizes the use of harmful substances.
Põhiomadused
Device Interfaces
• 24 10/100/1000 Gigabit ports
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.1p QoS
• IEEE 802.3x Flow Control supported for Full Duplex, Auto-Negotiation
• IEEE 802.3az Energy Efficiency Ethernet
Data Transfer Rates
• Ethernet: 10 Mbps/20 Mbps (Half-duplex/Full-duplex)
• Fast Ethernet: 100 Mbps/200 Mbps (Half-duplex/Full-duplex)
• Gigabit Ethernet: 2000 Mbps (Full-duplex)
Network Cables
• Ethernet: 2-pair UTP Cat.3/4/5/5e, Unshield Twisted Pair (UTP )Cable
• Fast Ethernet: 2-pair UTP Cat.5/5e, Unshield Twisted Pair (UTP )Cable
• Gigabit Ethernet: 4-pair UTP Cat.5/ 5e, Unshield Twisted Pair (UTP )Cable
D-Link Green Features
• Power saving by link status
Security
• Storm Control
QoS (Quality of Service)
• 802.1p priority
• 4 queues
VLAN
• Port Based VLAN
L2 Features
• Cable Diagnostics
Protocol
• CSMA/CD
Packet Buffer RAM
• 512 KBytes per device/Kbits per device
Filtering Address Table
• 8K MAC address per device
Packet Filtering/Forwarding Rate
• Full wire speed
MAC Address Learning
• Self-learning, auto-aging
Forwarding Mode
• Store-and-forward
Topology
• Star
Switching Capacity
• 48 Gbps
Max. Forwarding Rate
• 35.71 Mbps
Port Packet Filtering
• 10M: 14,880 pps
• 100M: 148,800 pps
• 1000M: 1,488,000 pps
Physical Parameters
LED Indicators
• 24 Link/Activity/Speed LEDs (one per port)
• Power LED
DIP Switches
• Energy-Efficient Ethernet (EEE)
• Flow Control
• Port Isolation and Storm Control
AC inputs
• Internal universal power supply
• 100~240VAC; 50-60Hz, 0.4A Max.
Maximum Power Consumption
• 12.5 watts
Standby Power Consumption
• 5 watts
Maximum Heat Dissipation
• 42.66 btU/h
Standby Heat Dissipation
• 17.06 btU/h
MTBF
• 1,157,698 hours
Acoustic Value
• 0dB(A) Fanless
Dimensions
• 280 x 180 x 44 mm
Weight
• 1.35 kg
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 5% to 90% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
Emission Certifications (EMI)
• FCC Class A
• ICES-003 Class A
• CE Class A
• VCCI Class A
• C-Tick Class A
• CCC
• BSMI
• KCC
Safety
• cUL/UL
• CB
• CCC
• BSMI
• CE(LVD)
Sertifikaadid
Sidustooted
