DGS-1008DEOL EOS
8-Port 10/100/1000 Unmanaged Switch
Kirjeldus
The DGS-1008D 8-Port 10/100/1000 Unmanaged Switch is an economical, plug-and-play networking switch solution for SOHO and small and medium businesses that seek to benefit from the increased bandwidth of Gigabit Ethernet. It provides five/eight Gigabit ports that enable you to easily expand your network and provide a quick way to upgrade your network to Gigabit connectivity. Rounding out the feature list are Quality of Service (QoS) support and Energy-Efficient Ethernet (EEE) for smoother performance and cost savings.
Fast and Reliable Networking
With data transfer speeds of up to 2000 Mbps on Gigabit Ethernet, the D-Link DGS-1008D 8-Port 10/100/1000 Unmanaged Switch is ideal for tasks such as file transfers and Internet telephony. Support for 802.3x Flow Control and Quality of Service means smoother network traffic and fast data transfer speeds for priority data types, resulting in an overall boost in performance and reliability.
Versatile Business-friendly Features
The DGS-1008D features front, easy-to-access Ethernet ports with two color LED indicators per port to easily distinguish link status. Cable Diagnostics simplifies troubleshooting for defective network cables at a glance of the LED panel and plug-and-play lets administrators quickly connect the switch to devices with no hassles. Additionally, the DGS-1008D features a Kensington Security Slot on the rear panel where users can fasten the unit to a shelf or desk so the device won’t be accidentally moved or stolen.
Conserve Energy
The 8-Port 10/100/1000 Unmanaged Switch features D-Link’s Green Technology to save energy and reduce heat, which in turn extends product life without sacrificing performance or functionality. The switch supports IEEE 802.3az Energy-Efficient Ethernet (EEE) which cuts down on power consumption during periods of low data activity, and will proceed to put the unused port into sleep mode, saving a substantial amount of power. In addition, the switch can also save energy by detecting the length of cable connected to a port and use as little power as possible. Both of these features work together to help you save power automatically.
Environmentally-friendly
The 8-Port 10/100/1000 Unmanaged Switch was designed with the environment in mind. It is compliant with Energy Star Level VI, CEC, and MEPS egulations which require the use of energy efficient power adapters. The switch is built to comply with RoHS standards to minimize use of hazardous materials and is packaged with an Energy Star Level VI qualified power adapter in a recyclable packaging making this product truly environmental friendly.
Smooth Streaming
The DGS-1008D features QoS which prioritizes network traffic so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media, VoIP calls, and online gaming.
Põhiomadused
Device Interfaces
• Eight 10/100/1000 Gigabit LAN ports
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3ab 1000BASE-T
• IEEE 802.3x Flow Control
• IEEE 802.1p QoS
Advanced Features
• Green Ethernet
• 16 Gbps switching fabric
• Auto MDI/MDIX crossover for all ports
• Secure store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• Supports 9,720 Bytes Jumbo Frames
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Supports Cable Diagnostics Function
Protocol
• CSMA/CD
Data Transfer Rates
• Ethernet:
10 Mbps (half duplex)
20 Mbps (full duplex)
• Fast Ethernet:
100 Mbps (half duplex)
200 Mbps (full duplex)
• Gigabit Ethernet:
2000 Mbps (full duplex)
Transmission Method
• Store-and-forward
MAC Address Table
• 4 K
Packet Filtering/Forwarding Rates
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
• Gigabit Ethernet: 1,488,000 pps per port
RAM Buffer
• 192 KB per device
LED Indicators
• Per port: Link/Activity/Speed
• Per device: Power
Media Interface Exchange
• Auto MDI/MDIX adjustment for all ports
Dimensions
• 128 x 68 x 27 mm
Weight
• 200 grams
Power
• 5 V/1 A Power Adapter
Power Consumption
• Power On (Standby): AC input: 0.8 watts
• Maximum: AC input: 4.7 watts
Temperature
• Operating: 0 to 40 В°C
• Storage: -10 to 70 В°C
Humidity
• Storage: 5% to 90% non-condensing
MTBF
• 1,061,111 hours
Certifications
• CE class B
• FCC class B
• ICES-003 Class B
• VCCI class B
• cUL
• CB
• LVD
Sertifikaadid
Sidustooted
