DCS-6410EOL EOS
IP-kaamera РоЕ toetusega ja videosalvestuse võimalustega vähese valgustusega oludes
Kirjeldus
POWERFUL 24 HOUR SURVEILLANCE
D-Link’s DCS-6410 Day & Night PoE Dome Network Camera is designed for round-the-clock surveillance. A CCD (Charged-coupled Device) sensor delivers high-quality images without distortion, while mounted infrared LEDs allow for nighttime monitoring over distances of up to 49 feet (15 meters). These elements make the DCS-6410 an ideal camera for indoor surveillance applications in homes, offi ces and business facilities.
HIGH-QUALITY VIDEO MONITORING
The DCS-6410  supports  simultaneous dual-streaming  for  live monitoring and  recording, and delivers excellent  video quality. Embedded with a powerful SoC (System-on-Chip), the camera provides high-quality, real-time video compression in MPEG-4 and motion JPEG formats. D-ViewCam, the free, bundled software capable of recording and displaying 32 channels allows you to reliably monitor and record high-quality images. Leverage the camera’s built-in Samba client to directly transfer images and videos to a NAS without the need for any additional hardware or software.
CLEAR, SHARP IMAGES FROM EVERY ANGLE
The dome-shaped DCS-6410 provides for greater viewing angles making it ideal for monitoring narrow spaces like elevators. The camera is capable of recording in MPEG-4 and motion JPEG compression with D1/CIF/QCIF resolution for smoother performance. Images are delivered at a maximum resolution of D1 at up to 30 frames per second.
SURVEILLANCE ON THE GO1
The DCS-6410 supports 3GPP mobile surveillance. A live feed from the camera can be accessed on a 3G cellular network using a compatible cell phone, PDA or any device capable of RTSP (Real Time Streaming Protocol) streaming. This enables you to monitor your home or offi ce space in real time even when you are on the go.
FLEXIBLE CONNECTIVITY
Power over Ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. For effective surveillance around any space, this camera’s built-in 802.3af compliant PoE module eases the installation process by reducing the need to lay additional cabling. In addition, the 10/100BASE-TX Ethernet port connects seamlessly to local network or to the Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network. The DCS-6410 also features an RCA connector which can be integrated easily into your existing analog CCTV (Closed Circuit Television) system; helping you migrate from an existing analog security system to an IP-based solution.
EASY TO INSTALL AND EASIER TO MANAGE
The DCS-6410 can be mounted on a fl at surface or with a drop-ceiling bracket. Manage and monitor upto 32 cameras using D-Link’s D-ViewCam software. You can also set up automated e-mail alerts to be instantly informed of unusual activities. In addition, this network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (for example, mycamera.dlinkddns.com). This allows you to remotely access the camera without having to remember the IP address.
Põhiomadused
Võrguprotokollide toetus
IPv4, TCP, UDP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba-клиент, 3GPP
Sisseehitatud võrguliides
LAN
+ IEEE 802.3
+ IEEE 802.3
+ IEEE 802.3af PoE
+ Täisdupleksrežiimi toetus
+ Voojuhtimine 802.3х täisdupleksrežiimis
Kaamera omadused
+ Sisseehitatud 1/3'' CCD-sensor
+ Minimaalne valgustatus:
+ 0.1 lux @ F1.6 (standart)
+ 0 lux (15 m vahekaugus infrapunaanduriga)
+ Lääts: 4.3 mm, F1.6
+ Lahenduvus: 420 ТV-rida
+ AGC/AWB/AES
+ Elektroonne lukk:
+ NTSC: 1/60  ~ 1/100.000 sek
+ PAL: 1/50  ~ 1/100.000 sek
+ Infrapunaandur (diapasoon 15 m)
+ Vaatenurgad:
+ 92.4° diagonaalil
+ 55.3°  vertikaalil
+ 73.1° horisontaalil
Video funktsioonid
+ Pildi suuruse ja kvaliteedi määramine
+ Aja- ja tekstimärgised
+ 16x digitaalsuum
PAN/TILT funktsioonid
+ Pöördenurk:
  - 170° ~ -170° (käsitsi)
+ Kallutusnurk:
  - 60° ~ -15° (käsitsi)
Video lahenduvus:
NTSC toetus:
+ kuni 30 kaadrit 176x120
+ kuni 30 kaadrit 352x240
+ kuni 30 kaadrit 704x480
PAL toetus:
+ kuni 25 kaadrti 176x144
+ kuni 25 kaadrit 352x288
+ kuni 25 kaadrit 704x576
Video kompressimine
+ Samaaegne kompressimine MPEG4 ja MJPEG formaati
+ Samaaegne profiilide toetus: veebiotsing, eemalt jälgimine 3G mobiiltelefoni kaudu ja video salvestamine
+ JPEG
Audio
+ Bitikiirus:
+ GSM-AMR: 12,20 Kbit/s
+ PCM: 8 Kbit/s
+ Täisdupleks heliedastus
Indikaatorid
+ Link ja Power
Lisa sisendid ja väljundid
+ 2 sisendit
+ 1 väljund
Väliste seadmete pordi toetus
+ RS-485
Mälu
+ SDRAM: 64 MB
+ Flash ROM: 8 MB
Reset nupp
Tehasesätete taastamise nupp
Nõuded süsteemile
Windows  XP, Vista
Kaugjuhtimine
+ Häälestamine veebilehitseja kaudu
+ Piltide saamine ja salvestamine kõvakettale veebilehitseja kaudu
Turvalisus
+ Administraatori ja kasutajagrupi kasutajatunnuste kaitsmine
+ Autentimine parooli järgi
D-Viewcam tarkvara
+ 32 IP-kaamerate kaugjuhtimine ja kontroll
+ 32 kaamera kuvamine ühel ekraanil
+ Kõikide veebiliidese juhtimisfunktsioonide toetus
+ Video salvestamine liikumisanduri käivitamisel või käsitsi
Lisaseadmed
+ Välised kõlarid
Toide sisendil
+ 100-240 V vahelduvvool, 50/60 Hz 1,5 A
Toide väljundil
+ 12 V alalisvool, 1.25 А
Sertifikaadid
Sidustooted
Pildid
DCS-6410/A
Eestvaade
Failid
Vaadake samuti
