DCS-6110EOL EOS
Kirjeldus
POWERFUL SURVEILLANCE
D-Link’s DCS-6110 is a high-performance fi xed dome Network camera, ideal for home or business. Dome type cameras are very popular in CCTV system. DCS- 6110 targets entry level market. The VGA Progressive CMOS technology delivers exceptional picture quality. Use D-Link's SoC (system-on-chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-6110 supports simultaneous dual-streaming for live monitoring and recording. With the free-bundled 32-channel recording software, the DCS-6110 is an ideal solution for high quality viewing and reliable recording. With a built-in Samba client for NAS, the DCS-6110 Network camera does not need a direct connection to a PC or any other hardware or software to capture and transfer images.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
The DCS-6110 is recommended for indoor ceiling mounting, and thus prevents possible damage that may be caused by a burglar. This Network camera has a built-in three axis mechanism for wall mount installation. The DCS-6110 provides high quality real-time videos in MPEG-4 and JPEG compression with VGA/ QVGA/QQVGA resolution. It is suitable for narrow space surveillance, like an elevator.
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE1
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Anywhere within the 3GPP service area, users are offered a fl exible and convenient way to remotely monitor a home or offi ce in real time.
WIRED & PoE ACCESS
For effective surveillance in and around a building, this camera comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module, which eases the installation process and also gives you the freedom to place the camera where it's needed. In addition, the 10/100BASE-TX Ethernet port is also provided for convenient connection to an Ethernet network or to a broadband Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network.
SMART & EASY TO USE
The software allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts to be instantly informed of unusual activities. Fixed dome cameras usually uses fi xed focus lens, but the DCS-6110 also has a vari-focal lens. Vari-focal lens provides easier installation process because the board lens of dome camera is not like CS/C mount lens, it is not changeable. Drop ceiling bracket is another alternative option for an installation method. In addition, this Network camera supports the Universal Plug-n-Play feature, which allows computers running on Windows 2000/XP/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
Põhiomadused
Võrguprotokollide toetus
TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba-клиент, IP Filtering, 3GPP
Sisseehitatud võrguliides
Video algoritmide toetus
Video resolutsioon
Video funktsioonid
Bitikiirus
20 Kb kuni 4 Mb
Kaamera omadused
LAN
