Kirjeldus
A high-performance surveillance solution
The DCS-5605/DCS-5635 is a high performance camera for professional surveillance and remote monitoring. This network camera features motorized pan, tilt, and optical/digital zoom for ultimate versatility. The 10x optical zoom lens delivers the level of detail necessary to identify faces, license plate numbers, and other important details that are diffcult to clearly distinguish using digital zoom alone.
Advanced video encoding
To maximize bandwidth effciency and improve image quality, the DCS-5605/5635 offers real-time video compression in MJPEG, MPEG-4, and H.264 formats. The H.264 codec can reduce the size of a video stream by up to 80% compared to motion JPEG. Thus, less network bandwidth and storage space is required.
Surveillance on the go
The DCS-5605/5635 supports 3GPP mobile surveillance. A live feed from the camera can be accessed on a 3G cellular network using a compatible phone, PDAa or mobile device capable of RTSP (Real Time Streaming Protocol) streaming. This enables you to monitor your home or offce space in real time even when you are on the go.
The perfect match for your network
Two comparable models are available depending on your unique network requirements. The DCS-5605 includes an ethernet port, while the DCS-5635 offers both ethernet and 802.11n wireless interfaces. The wireless model offers installation fexibility and freedom of wireless connectivity in diffcult locations without the hassle of running ethernet cables. The wireless camera supports WEP and WPA-PSK/TKIP for establishing secure connections to your wireless network.
Easy to install and simple to manage
The DCS-5605/DCS-5635 can be mounted on a fat surface or with a metal wall mount. manage and monitor up to 32 cameras using D-Link’s D-ViewCam software. You can also set up automated e-mail alerts to be instantly informed of unusual activities. in addition, this network camera supports the universal Plug-n-Play feature, which allows computers running on Windows XP/Vista to automatically recognize the camera and add it to the network. sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (for example, mycamera.dlinkddns.com). This way, you may remotely access the camera without having to remember the IP address.
