DCS-45/A3EOL EOS
Outdoor Enclosure
Kirjeldus
The outdoor enclosures provide a cost-effective solution for protecting your D-Link network camera from the rigors of outdoor use. The fixed-type enclosures include heavy-duty, angle-adjustable mounting brackets that can be used to secure the camera on a vertical or horizontal surface. These enclosures maximize the full potential of your D-Link network cameras to secure and protect your home and business.
The DCS-45 is IP66 certified for weatherproof and dustproof operation. The housing is complete with an adjustable semi-cable managed bracket.
Põhiomadused
Supported devices
• DCS-2000
• DCS-3220
• DCS-3110
• DCS-3410
Dimensions
• 360 x 140 mm
Weight
• 1.48 kg
Material
• Aluminum Housing
Color
• Gray
Sertifikaadid
Sidustooted
DCS-45/B1  Outdoor Enclosure
Pildid
DCS-45/A3/A
Eestvaade
Failid
Vaadake samuti
