Toote omadused:
Full HD keeratav IP-kaamera Uus |
Kirjeldus:
The DCS-5615 Full HD Mini Pan & Tilt Dome Network Camera features 2 megapixel 1080p HD resolution combined with H.264 compression to enable high quality video footage to be recorded. The DCS-5615 connects to a network to provide high quality live video on a LAN and over the Internet.
Sharp Video Monitoring from Different Angles
With accurate, responsive pan/tilt movement and digital zoom, the DCS-5615 gives you full control, so you can quickly scan a wide area from a variety of angles, and 16x digital zoom lets you zoom in on specific areas for more detail. The DCS-5615 can also be set to automatically move to specific preset positions, allowing the camera to patrol particular areas of interest within a surveillence area.
Full HD Surveillance
The DCS-5615 delivers Full HD 16:9 widescreen IP video, making it easier to view and monitor footage. With the included D-ViewCam 32-channel recording software, the DCS-5615 provides a complete solution for high quality live viewing and reliable recording. The camera also has a built-in microSD card slot which can be used for local backup by storing important events on a microSD card.
Multiple Video Streams
The DCS-5615 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high quality and bandwidth-efficient compression formats. H.264 produces a small file size, making it useful for extended recording with high detail or for use in low bandwidth networks. MJPEG delivers excellent file integrity, ideal for situations which require extensive image detail. Additionally, the DCS-5615 supports multicast H.264 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-5615 includes an input port for connectivity to external devices such as IR sensors, switches, and alarm relays. The DCS-5615 also incorporates Power over Ethernet (PoE), allowing it to be easily installed in a variety of locations without the need for supplemental power cabling.
Tamper-proof
Tamper-proof features make the DCS-5615 camera suitable for tamper‑prone locations such as schools, retail locations or correctional facilities. The electronic tamper detection system can sense whenever the camera has been redirected, de-focused, blocked, or spray-painted, and respond promptly with a visible or audible alarm.
D-ViewCam for Management
The included D-Link D-ViewCam™ video management software allows users to manage up to 32 network cameras, set e-mail alert notifications, create recording schedules, and use motion detection to record important events directly to a hard drive. D-ViewCam™ also allows users to upload a floor plan to create a realistic layout of the premises where the cameras are located, further simplifying the management process.
en → et
Sharp videovalve erinevate nurkade alt
Vaadake samuti
