Kiirotsing
Toote omadused:
Vigilance 5 Megapixel H.265 Outdoor Bullet Camera
Põhiomadused:
Camera Hardware Profile
• 1/2.5” 5-megapixel progressive CMOS sensor
• 30 meter IR illumination distance
• Minimum illumination:
• 0.1 lux (color)
• 0.05 lux (B/W)
• 0 lux (IR LED on)
• Built-in Infrared-Cut Removable (ICR) Filter module
• 10x digital zoom
• Minimum object distance 0.5 m
• Focal length: 2.8 mm
• Aperture: F2.0
• Angle of view:
• (H) 90°
• (V) 50°
• (D) 104°
Camera Housing
• IP66 compliant weatherproof housing
• Wire-in bracket
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Temper detection alarm
• Configurable shutter speed, brightness, saturation, contrast, and sharpness
• WDR
• 3D filter
Video Compression
• Simultaneous H.265/H.264/MJPEG format compression
• H.265/H.264/MJPEG multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 2560 x 1440 up to 15 fps, 1920 x 1080, 1280 x 720, 800 x 448, 640 x 360 up to 30 fps
• 4:3 - 2560 x 1920 up to 15 fps, 1600 x 1200, 1440 x 1080, 1280 x 960, 800 x 600, 640 x 480 up to 30 fps
External Device Interface
• 10/100BASE-TX Fast Ethernet port
• Supports 802.3af PoE Class 2
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ARP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client
• SMTP client
• Samba client
• ONVIF-compliant
• FTP client
• HTTP server
• HTTPS (TLS, disable SSL v3)
• PPPoE
• Bonjour
• UPnP port forwarding
• RTP / RTSP/ RTCP
• IP filtering
• Multicast
• SNMP v1/v2c/v3
• QoS/CoS
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Remote management via D-ViewCamTM software
• Configuration interface accessible via web browser
• Remotely take snapshots/video clips and save to local hard drive
System Requirements for Web Interface
• Windows 10/8/7 or Mac OS X 10.9 and higher
• Internet Explorer 9 and higher (on Windows), Firefox 12-51, 52 ESR, Chrome 42 and higher, or Safari 9 and higher (on Mac OS X).
D-ViewCamTM System Requirements
• Operating System:
• 32-bit: Windows 8 / 7 (SP1)
• 64-bit: Windows 10 / 8 / 7 (SP1) / Server 2012 / Server 2008 R2
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
D-ViewCamTM Software Functions
• Remote management of several cameras
• Supports all management functions provided in web interface
• Viewing of several cameras on one screen
• Scheduled, motion triggered, or manual recording options
Weight
• 445 g ± 5 %
External Power Adapter (not included into the package contents)
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V DC 1.5 A
Power Consumption
• 3.2 (DC) / 3.1 W (PoE) ± 5%
Temperature
• Operating: -30 to 50 °C
• Storage: -20 to 70° C
Humidity
• Operating: 20 % to 80 % non-condensing
• Storage: 5 % to 95 % non-condensing
Certifications
• CE
• CE LVD
• ICES
• FCC
• RCM
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
