Kiirotsing
Tootmisest maha võetud mudel
Toote omadused:
WIRELESS G ADSL2+ 4-PORT ROUTER
Põhiomadused:
DEVICE INTERFACES
+  1 RJ-11 ADSL port
+  4 RJ-45 10/100BASE-TX Fast Ethernet LAN switch ports with auto MDI/MDIX
+  Built-in 802.11g WLAN
WIRELESS LAN
+  IEEE 802.11g standard
+  Frequency range: 2.4 GHz to 2.497 GHz
+  Wireless speed: up to 54Mbps
+  64/128-bit WEP data encryption
+  Multiple SSID
+  MAC-based ACL
+  WPA/WPA2 security with TKIP, AES support - WDS support
+  802.11e WLAN QoS (WMM/WME)
ADSL STANDARDS
+  ADSL: Full-rate ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G.hs)
+  ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A/L/M, ITU-T G.992.4 (G.lite.bis) Annex A
+  ADSL2+: ITU-T G.992.5 Annex A/L/M
ADSL DATA RATES
+  G.dmt: 8Mbps downstream, 832Kbps upstream
+  G.lite: 1.5Mbps downstream, 512Kbps upstream
+  ADSL2: 12Mbps downstream, 1Mbps upstream
+  ADSL2+: 24Mbps downstream, 1Mbps upstream
ATM & PPP PROTOCOLS
+  Multiple protocol encapsulation over AAL5
+  Bridged and routed Ethernet encapsulation
+  Logical Link Control (LLC) encapsulation
+  VC-based multiplexing
+  ATM Forum UNI3.1/4.0 PVC
+  ATM Adaptation Layer Type 5 (AAL5)
+  ITU-T I.610 OAM F4/F5 loopback
+  ATM QoS (Traffc Shaping)
+  PPP over ATM
+  PPP over Ethernet
NETWORK PROTOCOLS AND FEATURES
+  IP Static Routing
+  RIP
+  NAT
+  Virtual Server, Port Forwarding
+  DHCP server/client/relay
+  DNS Relay, DDNS
+  IGMP proxy
+  SNTP
FIREWALL/ACCESS SECURITY
+  NAT frewall
+  MAC Filtering
+  Packet Filtering (IP/ICMP/TCP/UDP)
+  Stateful Packet Inspection (SPI)
+  Denial of Service (DoS) prevention
+  Intrusion Detection System and logging
+  DMZ
VPN
+  Multiple IPSec/PPTP/L2TP pass-through
QOS
+  Traffc Prioritization/Classifcation
based on:
    - Port
    - 802.1p Priority Queues
    - Application port
    - User-defned (TCP/UDP/ICMP etc.)
+  3 priority queues per PVC
+  PVC/VLAN port mapping
+  IGMP v.2 snooping
CONFIGURATION/MANAGEMENT
+  Quick Installation Wizard
+  Web-based GUI
+  Web-based/TFTP frmware upgrade, confguration up/download
+  UPnP
+  SNMP v1, v2c, built-in MIB-I, MIB-II agent
+  TR-069 compliant
+  Factory reset button
Füüsilised parameetrid
DIAGNOSTIC LEDS
+  Power
+  Status
+  DSL
+  WLAN
+  LAN 1 to LAN 4
+  Internet
POWER
+  Power input: through 12VDC/1A, 100 to 120VAC 50/60Hz or 200 to 240VAC 50/60Hz external AC power adapter
+  Power ON/OFF switch
+  Dying Gasp support
DIMENSIONS
200 mm (L) x 120 mm (W) x 33 mm (H)
(7.87 x 4.72 x 1.30 inches)
WEIGHT
343.5 grams (0.76 lb)
OPERATING TEMPERATURE
0˚ to 40˚ C (32˚ to 104˚ F)
STORAGE TEMPERATURE
-20˚ to 65˚ C (-4 ˚ to 149˚ F)
OPERATING HUMIDITY
5% to 95% non-condensing
Emission (EMC/EMI)
+  FCC Part 15 Class B
+  CE (EN55022/EN55024/EN300 328/EN301 489)
Safety
+  CSA
+  LVD
+  RoHS compliant
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast
