DWC-1000Projektideks
Traadita kontroller 2 porti 10/100/1000 (option*) + 4 porti 10/100/1000 LAN
Kirjeldus
The D-Link DWC-1000 Wireless Controller is a centralized wireless LAN manager developed specifically for campuses, branch offices, and small-to-medium enterprises (SMBs). With the ability to manage up to six wireless access points (upgradable to 24) and a maximum of 96 wireless access points in a Controller Cluster, the DWC-1000 is a cost-effective mobility solution for small to medium-scale environments. Its auto-managed AP discovery and single point management allow customers to acquire an enterprise class system without the burden of executing massive and complex configurations. With a robust and comprehensive security detection system, the DWC-1000 also enables managed APs to block potential attacks from unauthorized users and devices, especially for wireless environments.
Robust and Optimized Network
The DWC-1000 features a self-organizing, self-optimizing, and self-healing network capability to increase the stability of the entire wireless network. With regular-based radio scanning and performance analyzing, the DWC-1000 automatically adjusts radio channels and power periodically to avoid interference and keep the wireless network in an optimized state. To make up for a sudden RF signal vacuum created by any “dead” access point, the DWC-1000 will increase the transmit output power of neighboring access points to expand RF coverage.
Comprehensive Security
The DWC-1000 provides a comprehensive wireless security solution for any network. On the wireless side, empowered by a Wireless Instruction Detection System (WIDS), the DWC-1000 detects rogue access points and rogue clients as well as anticipates wireless threats, preventing any potential damage and illegal access. In addition to other fundamental wireless security features including WEP, WPA Personal/Enterprise, WPA2 Personal/Enterprise, and MAC Authentication to determine the identity of wireless devices, the Captive Portal feature allows you to block clients from accessing the network until the clients verify their identities. This double-layer authentication and authorization provides a robust security fence to also protect against attacks from within the network.
High Scalability, Availability, and Flexibility
Many companies are frequently changing in terms of size and organizational structure. To address such changing needs, the DWC-1000 offers a new dimension in feature selections: administrators  can purchase a Business Wireless Plus license to upgrade the DWC-1000’s capabilities. D-Link offers two types of Business Wireless Plus licenses: an AP license upgrade and a VPN license upgrade. The AP license upgrade increases the number of manageable access points. The DWC-1000 Wireless Controller manages up to six access points by default and after AP license upgrading, can manage up to 24 access points per controller.
The VPN license upgrade enables the DWC-1000 to provide VPN, Router, and Firewall functionality. The firewall function allows administrators to control network access by setting classification policies. The dual Option ports provide link failover and provide Internet connection redundancy to ensure Internet access. The virtual private network (VPN) features provide secure remote control to manage access points in branch offices. Site-to-site VPN tunnels use IP Security (IPSec) Protocol, Point-to-Point Tunneling Protocol (PPTP), or Layer 2 Tunneling Protocol (L2TP) to facilitate branch office connectivity through encrypted virtual links. In addition, the Secure Sockets Layer (SSL) VPN tunnels empower your mobile users by providing remote access to a central corporate database.
Simplified Management
Centralized remote control of managed access points provide a simple way to automatically discover compatible D-Link Wireless Access Points add them into the managed access point list, and configure them with one-time configuration dispatch settings. With the controller clustering feature, the administrator can easily log into one wireless controller and perform essential configurations on others within the group. The real-time monitoring of access points and associated client stations enablethe efficient utilization of network resources. Systemalarms and statistics reports on managed access points also help the administrator to use the DWC-1000 to manage, control, and optimize network performance.
Põhiomadused
Interface
• Ethernet: 2-port 10/100/1000 Option *, 4-port 10/100/1000 LAN
• USB: 2 USB 2.0 ports
• The console port: RJ-45
Performance
• The maximum number of access points to the device (default / after the upgrade): 6/24
• The maximum number of access points in a cluster (default / after the upgrade): 24/96
• Number of concurrent users passing on an adaptive authentication portal (wired / wireless network): 124/400
• Dedicated tunnels VPN IPSec: 70 **
• Dedicated tunnels VPN PPTP / L2TP: 25 **
• Dedicated tunnels VPN SSL VPN: 20 **
Office of the access points
• Compatible Managed AP: DWL-8600AP, DWL-6600AP, DWL-3600AP
• Control and detection of TH: Layer-2, Layer-3
• Monitoring the AP:
  - Managed AP
  - Unauthorized AP
  - TD is not authenticated
  - Autonomous APs
• Monitoring client
  - The authenticated client
  - Unauthorized client
  - The client is not authenticated
  - Client Ad-hoc
• Support for centralized management of security policy / RF
Roaming
• Fast roaming
• Roaming between controllers and access points connected to one controller
• Intra-and inter-subnet roaming
Security
• Wireless Network Security
  - WEP, Dynamic WEP
  - WPA Personal / Enterprise
  - WPA2 Personal / Enterprise
• Intrusion Detection System in Wireless Network (WIDS)
  - Classification of rogue access points and the actual
  - Rogue AP Mitigation
• Secure LAN
  - Access control 802.1x port-based and Guest VLAN
• Authentication
  - Adaptive Portal
  - Authentication by MAC-addresses
VLAN
• Group VLAN: Up to 255 entries
• 802.1q VLAN Tagging
• VLAN-based subnets
• VLAN-based port
Firewall **
• Policies
  - Support for 100 rules for each function
  - Up to 600 firewall rules
• Dynamic mashrut: RIPv1, RIPv2
• Dynamic DNS
• NAT, PAT
• Web-content filtering
  - Static URL
  - Keywords
Installing  **
• Redundant route
• Load Balancing
Virtual Private Network (VPN)
• The types of encryption: DES, NULL
• IPSec NAT Traversal
• Detection of inactive nodes
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
SSL Virtual Private Network (SSL VPN) **
• Message integrity: MD5, SHA1
Management
• Web-interface: HTTP
• Command Line Interface
• SNMP: v1, v2c, v3
Sertifikaadid
Sidustooted
Pildid
DWC-1000/А1
Eestvaade
Tagantvaade
DWC-1000/С1
Eestvaade
Paremvaade
Tagantvaade
Failid
Vaadake samuti
