DAP-1353EOL EOS
Kirjeldus
ULTIMATE PERFORMANCE
The D-Link RangeBooster N 650 Access Point DAP-1353 is a draft 802.11n compliant device that delivers real world performance of up to 650% faster than 802.11g wireless connection and transmission rates faster than 100Mbps wired Ethernet.1 Providing connectivity for wireless computer users and wireless LAN nodes such as print servers on the 2.4GHz frequency band, this Access Point provides a fast wireless performance while remaining fully compatible with 802.11g and 802.11b devices. Connect this RangeBooster N 650 Access Point to an Internet-enabled wired network and wirelessly share high-speed Internet. For superior performance, add other RangeBooster N 650 devices such as the RangeBooster N 650 notebook and desktop adapters, and enable a wireless coverage that extends to virtually every corner of your home or offce.
EXTENDED HOME NETWORk COVERAGE
Powered by RangeBooster N 650 Technology, this high-performance Access Point provides superior network coverage while minimizing dead spots. Utilize the three adjustable antennas to confgure optimal settings specifc to your environment. The RangeBooster N 650 Access Point is designed for use in bigger homes/offces and for users that demand higher networking performance.
EASY TO SETUP, EASY TO USE
D-Link’s Wireless Network Wizard guides you step-by-step through the installation process. Confgure this Access Point without having to call a networking expert to help you. Create a draft 802.11n wireless network with a data throughput capable of intense gaming, audio/video streaming, and large fle transfers. Delivering best-in-class wireless performance, superior network security, and enhanced network coverage, the RangeBooster N 650 Access Point is an integral piece for your next generation wireless network.
Põhiomadused
Standardid
Sagedusdiapasoon
2400 - 2497 МHz
Kodeerimismeetod
DSSS, OFDM
Modulatsiooni skeemid
DBPSK, DQPSK, CCK ja OFDM (BPSK/QPSK/16-QAM/64-QAM)
Andmeedastuskiirus
Antennid
3 eemaldatavat dipoolantenni võimendusteguriga 3dBi (ühenduspesa RP-SMA)
Ethernet liides
10/100BASE-TX port
Turvalisus
Töörežiimid
QOS ja tootlikkus
Juhtimine
