Kiirotsing
Toote omadused:
10/100/1000 Mbps to SFP Media Converter
Põhiomadused:
Max. Forwarding Rate
• 10 M: 14, 880 pps
• 100 M: 148,800 pps
• 1000 M: 1,488,000 pps
Forwarding mode
• Cut-Through
Packet Buffer Memory
• 256 Kbits
Switching Capacity
• 2 Gbps
LAN
• 1 x 10/100/1000 Mbps port
• IEEE 802.3u
• IEEE 802.3x
• IEEE 802.3ab
• Auto-Negotiation for each port
• Full-Duplex operation at 1000 Mbps
• Half/Full-Duplex operation at 10/100 Mbps
• Back pressure at Half-Duplex operation
• Auto MDI/MDIX
• Wire speed reception and transmission
• Supports Jumbo frames up to 9216 bytes at 1000 Mbps
Physical Parameters
External Power Adapter
• Switching 5V/1A Level V Power Adapter, ErP compliant
Power Consumption (Max.) at 240 V
• DC 2.34 W
• AC 3.46 W
Power Consumption (Standby) at 240 V
• DC 1.49 W
• AC 2.06 W
Heat Dissipation (Max.)
• 11.81 BTU/h
MTBF (hours)
• 506,711
Operation Temperature
• 0° to 50°C
Storage Temperature
• -10° to 70°C
Operating Humidity
• 10 to 90%
Storage Humidity
• 5 to 90%
EMI
• EMI: CE class A, FCC class A, VCCI class A, BSMI class A
Safety
• LVD, UL/cUL
* DMC-G01LC only
Füüsilised parameetrid
Tooted ja lahendused | Tootetugi  | Uudised  | Firmast |
