DFE-528TXEOL EOS
PCI Fast Ethernet Adapter
Kirjeldus
High Performance
With 32-bit Bus Master operation, the card guarantees the highest performance for power workstations and servers. Bus Master transfers data directly between the card and the host, bypassing the host CPU to alleviate its workload. This allows the host to concentrate on the application at hand.
10/100Mbps Flexible Connection
The card single connector connects to either 10BASE-T Ethernet or 100BASE-TX Fast Ethernet. 10/100Mbps speeds are auto-negotiated, completely without users need to intervene.
Full Duplex Support
Full/half duplex operations are auto-negotiated in both 10BASE-T and 100BASE-TX modes. When connected to a switch in full duplex, the network speed can be increased to 200Mbps, making the card an ideal NIC for high-speed workstation deployment.
Key Features
- 10/100Mbps auto-sensing with single shielded RJ-45 connector
- 32-bit PCI Bus Master operation
- Full/half duplex support
- Low network command processing overhead
- Runs Win95, 98, NT, ME, 2000, NetWare, Unix
- Easy-to-view diagnostic LEDs
