DES-102FEOL EOS
2-Port 100BASE-FX Fiber Module for DSS-24+
Description
The DES-102F is a two-port Ethernet module design to support the DSS-24+ Switch as an optional slide in module, which provides a two port 100BASE-FX Fast Ethernet connection. As an expansion module, the DES-102F increases connection distances without requiring signal regeneration using a repeater to re-boost the signal. With the two SC type port connectors, connection utilizing a fiber link can be initiated to servers or backbone switches for network expansion. DES-102F is targeted at small and medium businesses.
The DES-102F is compliant with IEEE 802.3u 100BASE-FX standard, supporting both auto-negotiation at full duplex modes and flow control signaling on each individual port. Being an expansion module, the DES-102F endorses all of the Layer 2 functionalities of the DSS-24+.
General features
Specifications
  • 100BASE-FX (SC-Type Connector)
  • IEEE 802.3u 100BASE-FX Compliant
  • All Ports support Full Duplex and Half Duplex Operations
  • 2-Port 100 Mbps
  EMI       Based on the DSS-24+ EMI
  • FCC Class A
  • CE Mark Class A
  • VCCI Class A
  • BSMI Class A
  • C-Tick Class A
  Weight       0.56 Lbs
  Dimensions       7 Ѕ x 10 Ѕ x 2.0
Certificates
Order info
DES-102F   2-Port 100BASE-FX Fiber Module for DSS-24+
Pictures
DES-102F/B2
Front view
Downloads
Support Resources
