DGS-701EOL EOS
Description
Hot Swappable
All D-Link GBIC transceivers are hot-swappable. You can remove or replace the GBIC transceiver with the system powered on. This permits modules and GBICs to be added or swapped without interrupting the network.
Full Size GBIC
All transceivers described in this datasheet have full GBIC size. (D-Link Mini GBIC transceivers are described in a separate brochure). These transceivers slide into a full-size GBIC slot. They provide the necessary signal amplification for data to be transmitted to the network cable from the port, and vice versa, for the port to receive data from the network cable.
Applications
Applications of the fiber transceivers include distributed multi-processing, Gigabit switch cascading, high-speed I/O file transfer, bus extension application, and channel extender/data storage.
General features
Multi-mode Fiber Transceiver (550 m)
- SC 1000BASE-SX port (IEEE 802.3z standard)
- Full duplex operation
- 802.3x flow control support
- Fiber type: 50um/125um 500MHz-km multi-mode fiber up to 550 m
- Wave length: 850 m
- Power support: 3.3V
Certificates
Order info
GBIC Transceiver
DGS-701 For 1000BASE-SX, multi-mode fiber, 550 m max.
