DES-1005PEOL EOS
5-port 10/100 switch with one PoE port
Where to buy
Description
FAST INTERNET CONNECTION AT HOME
The D-Link DES-1005P 5-port 10/100 Switch with One PoE Port allows you to easily connect a Power over Ethernet (PoE) device such as a wireless access point (AP), IP camera, or IP phone. The switch also gives you the opportunity to add additional Ethernet devices such as computers, printers, and Network Attached Storage (NAS) onto your network. This compact PoE switch operates quietly, making it ideal for use in virtually any room or office.
POWER OVER ETHERNET (PoE)
The first port of the DES-1005P supports the IEEE 802.3af PoE standard. The port supplies a total PoE budget of 15.4 watts, allowing users to attach an IEEE 802.3af-compliant device to the DES-1005P that requires no additional power. Use PoE for applications that are far from power outlets or when you want to minimize the clutter of extra cables.
AUTO MDI/MDIX CROSSOVER
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
CONSERVES ENERGY
The DES-1005P 5-Port 10/100 Switch makes use of D-Link green™ eco-friendly technology, providing energy savings, reduced power consumption, and a longer product life without sacrificing operational performance or functionality. This switch helps to conserve energy through methods such as Link Status and Cable Length Detection. The Link Status feature automatically powers down ports that have no link, allowing the switch to save substantial amounts of energy by cutting power for unused ports or ports connected to computers that have been shut down. It can also detect connected cable lengths, and adjust power usage accordingly, helping you save energy without affecting networking performance. In addition, the fan-less design extends the switch’s life and also reduces noise.
General features
KEY FEATURES
• Five 10/100 Mbps fast Ethernet ports with one PoE enabled port
• Auto MDI/MDIX Crossover for all ports
• Store-and-forward Switching Scheme
• Full/half-duplex for Ethernet/fast Ethernet Speeds
• IEEE 802.3x flow Control
• Plug-and-play Installation
• Built-in D-Link green Technology
• RoHS Compliant
• IEEE 802.1p QoS (4 Queues, Strict Mode)
SWITCHING CAPACITY
1 gbps
STANDARDS
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX fast Ethernet
• ANSI/IEEE 802.3 NWay Auto-negotiation
• IEEE 802.1p QoS
POE FEATURES
• Supports IEEE 802.3af
• Supplies power to PD:  up to 15.4 watts
• Total PoE budget: 15.4 watts
• PoE port count/Average PoE watts
DATA TRANSFER RATES
• Ethernet:
 ƒ 10 Mbps (half duplex)
ƒ  20 Mbps (full duplex)
• Fast Ethernet:
  100 Mbps (half duplex)
  200 Mbps (full duplex)
TOPOLOGY
Star
MEDIA INTERFACE EXCHANGE
Auto MDI/MDIX adjustment for all ports
NETWORK CABLES
• 10BASE-T
• UTP CAT 3/4/5/5e (100 m max.)
• EIA/TIA-586 100-ohm STP (100 m max.)
• 100BASE-TX
• UTP CAT 5/5e (100 m max.)
• EIA/TIA-568 100-ohm STP (100 m max.)
LED INDICATORS
• Per port: Link/Activity/Speed/PoE Status
• Per device: Power/PoE Max
TRANSMISSION METHOD
Store-and-forward
MAC ADDRESS TABLE
2K Entries per device
MAC ADDRESS LEARNING
Automatic update
PACKET FILTERING/FORWARDING RATES
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
RAM BUFFER
64 KBytes per device
POWER CONSUMPTION
• Power On (Standby):
  DC input: 0.9 watt
  AC input: 1.8 watts
• Maximum (PoE Off)
  DC input: 2.05 watts
  AC input: 2.7 watts
• Maximum (PoE On)
  DC input: 17.29 watts
  AC input: 20.2 watts
POWER ADAPTER
Switching 48 V/0.5 A Level V power adapter
MTBF
324,616 hours
OPERATING TEMPERATURE
0 to 40 ˚C
STORAGE TEMPERATURE
-40 to 70 ˚C
OPERATING HUMIDITY
0% to 95% RH non-condensing
STORAGE HUMIDITY
DEVICE DIMENSIONS (W x D x H)
140 x 85 x 28 mm
CERTIFICATIONS
• FCC Class B
• ICES-003 Class B
• cUL
Certificates
Order info
DES-1005P/A1 5-port 10/100 switch with one PoE port
Pictures
DES-1005P
Вид сзади
Downloads
Support Resources
