Quick find
Product features:
Unmanaged 8-Port Gigabit Switch
Description:
Think Green
The D-Link 8-Port Gigabit Switch is part of D-Link’s new series of SOHO devices that make use of D-Link’s Green technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. An energy-efficient power adapter (EnergyStar Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
Conserve energy
The DGS-1008 Switch helps you conserve energy through IEEE802.3az EEE, saving feature automatically puts the switch into a low-power idle state when the switch utilization is zero, allowing you to lower your energy usage and save on your energy costs.
Environmentally friendly
The 8-Port Gigabit Switch was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
Products | Support  | News  | About |
