Quick find
Product features:
24-port 10/100Mbps Switch With 2 Gigabit Copper/SFP ports
Description:
The  DES-1026G  is  an  unmanaged  10/100  Mbps  switch  designed  to  enhance  workgroup performance  while  providing  a  high  level  of  flexibility.  It  provides  24  10/100Mbps  ports  for workstation  connection,  plus  2  copper/SFP  Gigabit  ports  for  server  deployment,  allowing  a workgroup to multiply bandwidth, boost response time, and satisfy heavy load demands.
Increased Productivity
The  DES-1026G  comes  with  24  10/100  Mbps  ports,  allowing  a  small  workgroup  to  flexibly integrate to Ethernet and Fast Ethernet. These intelligent ports detect the network speed and auto-negotiate between 100BASE-TX and 10BASE-T, as well as between full and half-duplex, letting you focus on work-day productivity rather than connectivity issues.
Instantly Upgrade to Gigabit Speeds 2  Copper/SFP  Gigabit  ports  provide  an  alternative  solution  to  fiber-optic  or  copper twisted-pair wires as the transmission media, allowing you to instantly upgrade your servers to Gigabit capability without requiring installation of new, expensive fiber cables. Both ports support 10/100/1000 Mbps network speed auto-sensing and full/half-duplex auto-negotiation, keeping  you  up  to  date  with  the  latest  technologies  in  switch  connectivity.  Additionally,  all ports support flow control, which minimizes dropped packets by sending out collision signals when the port’s receiving buffer is full, ensuring reliable connectivity.
Plug and Play
All ports support auto-negotiation of MDI/MDIX cross over, which eliminates the need for cross over cables or uplink ports. Any port can simply plug to a workstation, a server, a hub or a switch using the usual straight-throughtwisted-pair cable, saving you time and money. With 26 plug-and-play ports, the switch is a perfect choice for workgroups to upgrade performance in a client/server environment. The ports can be connected to workstations and servers in fullduplex, or hubs in half-duplex.
Products | Support  | News  | About |
