DGS-1100-08
Eight 10/100/1000Base-T Port EasySmart Switch
Where to buy
Description
D-Link’s DGS-1100 Series EasySmart Switches provide an affordable solution for SOHOs and Small and Medium Businesses as well as enterprise deployment, such as in branch offices and meeting rooms that require simple network management. Each model comes in a compact desktop-sized metal case and features either 5, 8, 16, or 24 Gigabit ports.
D-Link Green/Power Saving Performance
Compliant with IEEE 802.3az Energy Efficient Ethernet, these switches consume less energy by cutting down on power consumption when port utilization is low. By deploying EEE devices, users can cut operating costs and even cut down on necessary cooling equipment, helping small and medium-sized businesses stay within their budgets. The DGS-1100 Series also features D-Link Green Technology that helps automatically save energy. The switches automatically detect the length of the connected cables and can adjust power usage for cables shorter than 20 meters. In addition, the switches monitor the link status of every port and will drastically reduce power consumption when a port link is down.
Easy to deploy
The DGS-1100 Series EasySmart Switches support an intuitive SmartConsole Utility and a web-based management interface. The SmartConsole Utility allows customers to discover all switches in the D-Link Smart Switch family within the same L2 network segment. With this utility, users do not need to change the IP address of their PC, and this also makes initial setup of the Smart Switches quick and easy. Switches within the same L2 network segment that are connected to the user’s PC are displayed on-screen for instant access. This allows for extensive switch configuration and basic setup of discovered devices, including password changes and firmware upgrades. The graphic web-based management interface provides a user-friendly interface that enables network administrators to remotely control their network down to the port level.
Surveillance VLAN and Bandwidth Control
The DGS-1100 Series supports Surveillance VLAN for video surveillance deployment. Surveillance VLAN gives video traffic high priority and an
individual VLAN, guaranteeing the quality of surveillance traffic through a single DGS-1100 switch, thus sparing businesses the added expenses required for dedicated hardware and facilities. Bandwidth Control can reserve bandwidth on a per port basis for important functions that require larger bandwidth or might have high priority.
PoE Support
The DGS-1100-08P delivers Power over Ethernet (PoE) capabilities, making deployment wit IP cameras, VoIP phones, and access points much easier. Power cords will become a thing of the past, as the DGS-1100-08P complies with the 802.3af standard for PoE and supports a 64 Watt power budget. The 10/100/1000Base-T Ethernet ports mean that even high-quality video is no problem.
Easy Troubleshooting
These EasySmart Switches feature Loopback Detection and Cable Diagnostics
to help network administrators find and solve network problems quickly and easily. Loopback Detection is used to detect loops created by a specific port and automatically shut down the affected port. The Cable Diagnostics feature is designed for network administrators to quickly examine the quality of the copper cables, recognize the cable type, and detect cable errors.
Advanced Features
DGS-1100 Series is equipped with advanced security features such as Static MAC, Storm Control, and IGMP Snooping. Static MAC allows users to create a MAC whitelist for specific ports, helping administrators limit network access to authorized devices only. Storm Control monitors broadcast, multicast, or unknown unicast traffic and will start blocking or discarding packets which could flood the network when the defined threshold is exceeded. IGMP Snooping is able to reduce the loading of L3 multicast routers and save bandwidth in network throughput.
General features
Size
• Desktop
Number of Ports
• 8 10/100/1000 Gigabit ports
Port Functions
• IEEE 802.3 compliant
• IEEE 802.3u compliant
• Supports half/full-duplex operation (half at 10/100Mbps, full at 1000Mbps)
• Auto-negotiation
• Auto MDI/MDIX
• IEEE 802.3x Flow Control supports Full-Duplex mode
• IEEE 802.3az compliant
Performance
Switching Capacity
• 16Gbps
Maximum Forwarding Rate
• 11.9Mpps
MAC Address Table Size
• 8K Entries
Packet Buffer
• 2Mbits
Flash Memory
• 2MB
LEDs
• Power (per device)
• Link/Activity/Speed (per port)
Power Consumption
Standby Mode
• 1.23 watts
Maximum
• 4.89 watts
Software Features
VLAN
• Port-based VLAN
• 802.1Q Tagged VLAN
• Surveillance VLAN
• Voice VLAN
• Management VLAN
• VLAN Group
  - Supports 32 static VLAN groups
  - Max. 4094 VIDs
L2 Features
• MAC Address Table: 8K
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo Frames up to 9216 Bytes
• IGMP Snooping
  - IGMP v1/v2 Snooping
  - Supports 32 Groups
• Link Aggregation
  - 2 groups, 2-4 ports per group
• Loopback Detection
• Cable Diagnostics
• Port Mirroring
  - One-to-One
• Statistics
  - Tx Ok
  - Tx Error
  - Rx Ok
  - Rx Error
Quality of Service (QoS)
• 802.1p Quality of Service
• 4 queues per port
• Queue Handling
  - Strict
  - Weighted Round Robin (WRR)
• Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 8Kb/s)
Security
• Static MAC Address
  - Up to 32 entries
• Broadcast/Multicast/Unknown Unicast Storm Control
Management
• Web-based GUI (Supports IPv4)
• SmartConsole Utility
D-Link Green
• Power Saving by
  - Link Status
  - Cable Length
• Compliant with IEEE 802.3az Energy Efficient Ethernet
• Compliant with RoHS 6
RFC Standard List
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 951 BootP Client
• RFC 1542 BootP/DHCP client
• RFC 1945 HTTP/1.0
• RFC 2647 802.1p
Power Input
• 100 to 240 V AC
• 50 to 60 Hz External Power Adapter
MTBF
• 503,585 hours
Acoustics
• 0dB
Heat Dissipation
• 16.68BTU/hr
Weight
• 0.42kg
Dimensions
• 171 x 98 x 28mm
Ventilation
• Fanless
Operating Temperature
• 0 to 50°C
Storage Temperature
• -10 to 70°C
Operating Humidity
• 10% to 95% non-condensing
Storage Humidity
• 5% to 95% non-condensing
EMI
• FCC Class A, CE Class A, VCCI Class A, ICES-003, C-Tick
Safety
• cUL, CE LVD
Certificates
Order info
DGS-1100-08   Eight 10/100/1000Base-T Port EasySmart Switch
Pictures
DGS-1100-08/B
Вид справа
Вид сзади
Downloads
Support Resources
