Quick find
Product features:
24-Port RJ21 to RJ45 Patch Panel For DES-6500 Chassis
Description:
The DES-6506 is a 24-port Ethernet patch panel for the DES-6500 chassis switch. This patch panel provides 2 sets of RJ-21 to RJ-45 connectors, each supporting 12 connections. The patch panel is designed to work with the 24-port 10/100BASE-TX DES-6510 module, also equipped with RJ-21 connectors. System integrators wishing to set up a high port density network can install the DES-6510 modules in the DES-6500 chassis together with the DES-6506 patch panels.
Products | Support  | News  | About |
