DES-6508EOL EOS
Description
The DES-6508 is a 16-port 10/100BASE-TX Ethernet module for the DES-6500 chassis switch. Designed to take full advantage of the DES-6500 chassis switch's advanced network functions that link core switches together , this 10/100BASE-TX module provides 16 RJ-45 ports for workstation connections. All ports support auto-sensing 10/100Mbps dual speeds, full/half duplex and auto-MDI/MDIX plug and play installation.
The DES-6508 10/100BASE-TX module fully complies with IEEE 802.3/802.3u and 802.3x standards. It supports 802.3x Flow Control for greater dependability and minimal packet loss.
General features
Standards
- IEEE 802.3 10BASE-T
- IEEE 802.3u 100BASE-TX
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Protocol
CSMA/CD
Topology
Star
Data Transfer Rates
- Ethernet:
10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
Network Cable
Ethernet Cat. 5 cable (max. 100 m)
Number of Ports
16 10/100BASE-TX Ethernet ports
Connectors
16 RJ-45
Certificates
Order info
DES-6508 16-Port 10/100BASE-TX Ethernet Module for DES-6500 Chassis Switch
