DGS-712EOL EOS
Description
The D-Link DGS-712 1000BASE-T Copper Small Form Pluggable (SFP) transceiver is based on the SFP Multi Source Agreement (MSA). It is compatible with the Gigabit Ethernet and 1000BASE-T standards as specified in IEEE Std 802.3z and IEEE Std 802.3ab. The 1000BASE-T physical layer IC (PHY) can be accessed via I2C, allowing access to all PHY settings and features.
The DGS-712 1000BASE-T copper SFP transceiver plugs into an SFP slot provided for on a D-Link Gigabit switch or optional switch module. It provides Gigabit transmission on the common Category 5 twisted-pair network cable.
General features
Standard
IEEE 802.3ab 1000BASE-T Gigabit Ethernet
Transceiver Type
SFP (Small Form Pluggable)
Connector
RJ-45
Auto MDI/MDIX
- Automatic crossover detection enabled
- External crossover cable not required
Data Rate
- 1,000 Mbps (IEEE 802.3 compatible)
- 10/100/1000 BASE-T operation requires the host system to have an SGMII interface with no clocks. With a SERDES interface, this transceiver will operate at 1000BASE-T only
Cable Type
Cat. 5 twisted-pair cable
Maximum Cable Distance Coverage
100 meters
Certificates
Order info
DGS-712 1000BASE-T Copper SFP Transceiver
