DEM-423XTProject
10GBASE-ER 10Gigabit Ethernet XFP Optical Transceiver, 40km
Where to buy
Description
Optical Data Communication
This transceiver provides a high performance and cost-effective solution for serial optical data communication applications specified for multi-mode supporting up to 10.7Gbps rate. It operates with +3.3V and +5V power supply. The transceiver is intended for multi-mode fiber, operates at a nominal wavelength of 1310nm and complies with Multi-Source Agreement (MSA) Small Form Factor Pluggable (XFP). The transceiver consists of a transmitter optical subassembly, a receiver optical subassembly and an electrical subassembly. It is housed in a metal package and the combination produces a reliable component.
Wide Ranging Applications
This fiber Gigabit transceiver is ideal for deployment as for Ethernet links, fiber channel links at 10Gbps, high-speed backbone interconnection and switched backbones.
General features
Standard
802.3ae 10GBASE-ER
Connector
Duplex LC
Wavelength
1550nm
Cable Type
9/125um Single-Mode Fiber
Maximum Cable Distance Coverage
40 km
Power Voltage
3.3V/5V
Certificates
Order info
DEM-423XT   XFP transceiver for 10GBASE-ER, single-mode fiber, max. distance 40 km, 3.3/5V
Pictures
DEM-423XT
Downloads
Support Resources
