DES-1210GEOL EOS
Description
8 10/100Mbps Ports
The switch comes with 8 10/100Mbps ports designed for flexible connection and Ethernet/fast Ethernet integration. These intelligent ports detect the network
speed and auto-negotiate between 100BASE-TX and 10BASE- T, as well as full- and half-duplex. The 10/100Mbps ports are ideal for segmenting the network into small, connected sub networks for superior performance, enabling the most demanding multimedia and imaging applications over the network.
2 Gigabit Fiber Ports
2 1000BASE-SX Gigabit ports are provided to handle very large amounts of data in a secure topology linking to a backbone or high-power servers.
High-bandwidth Port Trunking
Multiple ports can be combined into a high- bandwidth, full-duplex trunk for switch-to-switch or switch-to-server connection. Port trunking gives users the high-speed load- sharing connection.
VLANs for Performance and Security
The switch supports up to multiple port-based VLAN s to extend the broadcast domain, segment network traffic and improve performance and manageability.
This allows adds, moves and changes to be easily carried out. It also provides security by limiting broadcast domains, traffic in different segments and subnets can be separated for maximum throughput and secure networking.
Plug-and-Play with Easy Configuration
The switch provides plug-and-play connection to mixed bandwidth workgroups while letting the administrator easily set up port trunking and VLAN groups via a built-in console port.
General features
Standards
-IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
-IEEE 802.3u 1 OOBASE- TX Fast Ethernet (twisted-pair copper)
-IEEE 802.3z 1000BASE-SX Gigabit Ethernet (fiber)
-ANSI/IEEE Std 802.3 NWay auto-negotiation
-IEEE 802.3x full-duplex flow control
-IEEE 802.1p Priority Queue
Protocol
CSMA/CD
Data Transfer Rates
-Ethernet:
10Mbps(halfduplex)
20Mbps (full duplex)
-Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
-Gigabit Ethernet:
2000Mbps (full duplex)
Topology
Star
Network Cables
-10BASE-T:
2-pair UTP Cat. 3, 4,5 (100 m)
EIA/TIA-586100-ohm STP(100m)
-100BASE-TX:
UTP Cat. 5 (100 m max.)
EIA/TIA-568 100-ohm STP (100 m max.)
-1000BASE-SX:
62.5/125um multimode fiber-optics (275m max.)
50/125um multimode fiber-optics (550m max.)
Full/half Duplex
-Full/half duplex for 10/100Mbps ports
-Full duplex only for 1000Mbps fiber ports
Flow Control
-IEEE 802.3x compliant flow control for full duplex
-Back pressure flow control for half duplex
Media Interface Exchange
MDI-X switch button for 1 10/100Mbps port
Twisted-pair Rx Reverse Polarity
-Auto-correction
LED Indicators
-Per 10/100Mbps port:
100Mbps speed, Link/Act
-Per Gigabit port:
Link, Act
-Per device:
Power
Performance
Transmission Method
Store-and-forward
Filtering Address Table
17K entries per device
MAC Address Learning
-Automatic update
-Max Age: 680 sec. approx.
Packet Filtering/Forwarding Rates (half duplex)
-Ethernet: 14,880 pps per port
-Fast Ethernet: 148,810 pps per port
-GigabitEthernet.l,488,100pps per port
Priority Queue
-802.1p support
-4 priority queues
RAM Buffer
-2MB per 8 10/100Mbps ports
-2MB per Gigabit port
Number of Ports per Trunk
-Up to 4 10/100Mbps ports (800Mbps at full duplex)
-Up to 2 Gigabit ports (4000Mbps at full duplex)
Console Port
RS-232 DB-9
Certificates
Order info
Ethernet/Fast Ethernet Switch
DES-1210G 8 10/100Mbps ports, 2 1000Base-SX Gigabit fiber ports
