DGS-3426PEOL EOS
24-Port Gigabit L2+ Stackable Switch With 4 Combo SFP & 2 10GE Module Slots
Description
The xStack DGS-3400 series of next generation switches delivers performance, flexibility, security, multi-layer Quality of Service (QoS) and redundant power option for the SMB and enterprises. With high Gigabit port densities for desktop connections, SFP fiber connectivity, 10-Gigabit uplink options and enhanced Layer 2+ functions, these switches comprise the workgroup access-layer stack for seamless integration with L3 core switches to form part of a multi-level network structured with high-speed backbone and centralized servers.
Unparalleled Flexibility. Any switch in the DGS-3400 series can operate as a stand-alone device or part of a scalable stack. Embedded with Single IP Management capability, a stand-alone switch can form part of a virtual stack, where intra-stack traffic flows through the usual network wires, doing away with the costly stacking cables. Without stacking cables, cable distance barriers and physical stacking limitations, a virtual stack can comprise units that are located anywhere on the network that minimizes the impact of any single point of failure.
Redundant Ring Stacking.
Alternatively , optional 10-Gigabit modules can be installed in the open slots to create a physical stack. Up to 12 units or 576 Gigabit ports can be configured 1 for a stack. Users can install one or two single-port modules, depending on whether the linear or fault-tolerant Ring stacking is implemented. With each of these ports providing 20Gbps full duplex transmission on the cost-effective coaxial cable, the DGS-3400 series provides not only high-bandwidth stacking but also cost control capability that allows users to add ports strictly on a per need basis. Modules with single 10-Gigabit XFP can also be installed in any of the open slots for uplink to servers or a fiber backbone.
More Intelligent Than Simple Layer 2 Switches. The DGS-3400 series provides a complete set of security features, which includes L2/L3/L4 multi-layer Access Control Lists and 802.1x user authentication via TACACS+ and RADIUS servers. In addition, it offers suppression capabilities and Layer 3 IP v.4/v .6 Static Routing to increase network performance and security. Built-in D-Link ZoneDefense technology allows business to integrate the switch stack with D-Link NetDefend firewalls to implement a full coverage, proactive security architecture.
Security, Performance & Availability. The DGS-3400 series provides extensive VLAN support including GARP/GVRP and 802.1Q VLAN to enhance security and performance. To support converged applications including VoIP , ERP, Intranet and video conference, a robust set of L2/L3/L4 QoS/CoS features ensures that critical network services are served with proper priority. For prevent malicious flooding traffic caused by worm/virus infections, the DGS-3400 series provides D-Link Safeguard Engine to increase the switch's reliability, serviceability and availability. Bandwidth Control can be flexibly set for each port using pre-defined thresholds to assure a committed level of service for end users. For advanced applications, per-flow bandwidth control allows easy fine-tuning of service types based on specific IP addresses or protocols.
General features
Interface
- 24 10/100/1000BASE-T Ports
- Auto-Negotiation of Network Speed
- Auto-MDI/MDIX
- 802.3x Flow Control
- 4 SFP
- 2 Open Slot for 10Gigabit Uplink Modules
- 1 RS-232 Console Port
Physical Stacking
Installable Module for Stacking
Single-Port DEM-410CX Module or Single-Slot DEM-410X Module
Max Number of Stacking Ports Installable
2 CX4 Ports or 2 XFP Slots
Stacking Speed (Per Port)
20Gbps (Full-Duplex)
No. of Units Per Stack (Ring Topology)
12
Optional 10-Gigabit Uplink
- Single XFP Slot Module (DEM-410X)
- Single CX4 Port Module (DEM-410CX)
- 10GBASE-SR (300 m Multi-Mode Fiber) Support
- 10GBASE-LR (10 km Single-Mode Fiber) Support
- 10GBASE-ER (40 km Single-Mode Fiber) Support
- Max. Number of 10-Gigabit Uplinks Installable: 2
Performance
Switch Fabric
88Gbps
Packet Forwarding Rate
65.47Mpps
Packet Buffer
750KB
MAC Address Table
8K Entries
IP v.4/v .6 Static Routing Table
128 Entries
IP v.4 Host T able
2K Entries
IP v.6 Host T able
1K Entries
Jumbo Frame Size 9.216 Bytes
9.216 Bytes
Software Functions
L2 Features
- IGMP snooping supports:
IGMP v.1/v .2/v.3
1K IGMP groups
IGMP Fast Leave
Host-based IGMP Fast Leave *
- MLD snooping supporting 511 MLD snooping groups
- Spanning Tree: 802.1D STP , 802.1W RSTP , 802.1S MSTP
- Loop back detection
- 32 802.3ad Link Aggregation groups
- Back Pressure Flow Control
- Port mirroring: one-to-one, multiple-to-one, ACL modes *
- Trunking across stack
- Head-of-line blocking prevention
VLAN
- 802.1Q
- Double VLAN
- 4K VLAN groups
- GVRP
- Guest VLAN
- 802.1v
- MAC-based VLAN *
L3 Features
128 IP v.4/v .6 Static Routing
QoS
- Per flow bandwidth control
- 802.1p support
- 8 queues per port
- Queue handling methods: WRR, Strict
- CoS based on:
Switch port
MAC address
802.1p priority
VLAN
Protocol type
TOS
DSCP
IP v.4/v .6 address
IP v.6 traffic class
IP v.6 flow label
TCP/UDP port
User defined packet content *
ACL (Access Control List)
- Maximum 768 rules based on:
Switch port
MAC address
802.1p priority
VLAN
Protocol type
TOS
DSCP
IP address
IP v.4/v .6 address
IP v.6 flow label
TCP/UDP port
- Time-based ACL
- CPU interface filtering
- ACL Statistic *
Security
- RADIUS/TACACS/T ACACS+
- SSH v.2
- SSL v.3
- Port security
- 802.1x port-based/MAC-based access control
- Web-based access control *
- MAC-based access control *
- Broadcast storm control
- Traffic segmentation
- IP-MAC-Port binding (500 entries per device)
- D-Link Safeguard Engine
- Support Microsoft NAP
Management
- D-Link Single IP Management v.1.6
- Web-based GUI
- CLI
- Web GUI traffic monitoring
- Web MAC address browsing
- Telnet server
- Telnet client *
- TFTP client
- SNMP v.1, v .2c, v.3
- SNMP trap on MAC notification
- RMON v.1
- BootP/DHCP client
- DHCP auto-configuration
- DHCP relay option 82
- System log
- Trap/alarm/log severity control
- Flash file system
- Dual Images
- Dual Configurations
- CPU Monitoring
- LLDP *
MIBs
- MIB-II (RFC 1213)
- Bridge MIB (RFC 1493)
- SNMP v.2 MIB (RFC 1907)
- RMON MIB (RFC 1757, 2819)
- RMON v.2 MIB (RFC 2021)
- Ethernet-like MIB (RFC 1643, 2358, 2665)
- 802.1p MIB (RFC 2674)
- IF MIB (RFC 2233, 2863)
- RADIUS Authentication Client MIB (RFC 2618)
- RADIUS Accounting Client MIB (RFC 2620)
- Ping/Traceroute MIB (RFC 2925) *
- D-Link enterprise MIB
* Functions available in future firmware upgrade.
Certificates
Order info
DGS-3426P    24-port 10/100/1000Base-T L2+ Stackable Management PoE Switch with 4 Combo SFP and 2 open slots for optional 10GE modules
Optional Management Software
DS-510S
D-View 5.1 SNMP Network Management Program (standard version)
DS-510P D-View 5.1 SNMP Network Management Program (professional version)
Optional 10-Gigabit Uplink Modules
DEM-410X
1-slot 10-Gigabit XFP uplink module
DEM-410CX 1-port 10-Gigabit CX4 uplink module
Optional 10-Gigabit XFP Transceivers
DEM-421XT
XFP transceiver, 10GBASE-SR standard, multi-mode fiber, max. distance 300 m, 3.3/5V
DEM-422XT XFP transceiver, 10GBASE-LR standard, single-mode fiber, max. distance 10 km, 3.3/5V
DEM-423XT XFP transceiver, 10GBASE-ER standard, single-mode fiber, max. distance 40 km, 3.3/5V
Optional SFP Transceivers
DEM-310GT
SFP transceiver, 1000BASE-LX standard, single-mode fiber, max.distance 10km, 3.3V operating voltage
DEM-311GT SFP transceiver, 1000BASE-SX standard, multi-mode fiber, max. distance 550m, 3.3V operating voltage
DEM-312GT2 SFP transceiver 1000BASE-SX standard, multi-mode fiber, max. distance 2km, 3.3V operating voltage
DEM-314GT SFP transceiver, 1000BASE-LX standard, single-mode fiber, max. distance 50km, 3.3V operating voltage
DEM-315GT SFP transceiver, 1000BASE-LX standard, single-mode fiber, max. distance 80km, 3.3V operating voltage
DEM-330T WDM SFP transceiver, 1000BASE-LX standard, single-mode fiber, max. distance 10 km, 3.3V operating voltage, Tx wavelength 1550 nm, Rx wavelength 1310 nm
DEM-330R WDM SFP transceiver, 1000BASE-LX standard, single-mode fiber, max. distance 10 km, 3.3V operating voltage, Tx wavelength 1310 nm, Rx wavelength 1550 nm
DEM-331T WDM SFP transceiver, 1000BASE-LX standard, single-mode fiber, max. Optional SFP Transceivers distance 40 km, 3.3V operating voltage, Tx wavelength 1550 nm, Rx wavelength 1310 nm
DEM-331R WDM SFP transceiver 1000BASE-LX standard, single-mode fiber, max. distance 40 km, 3.3V operating voltage, Tx wavelength 1310 nm, Rx wavelength 1550 nm
Optional Redundant Power Supply
DPS-500 140-watt redundant power supply
DPS-600 500-watt redundant power supply
DPS-800 2-slot redundant power supply chassis
DPS-900 8-slot redundant power supply chassis
Pictures
DGS-3426P/A
Front view
Back view
Downloads
Support Resources
