Description
Wire-speed IP Packet Routing
Using standard-based routing, the DES-6300 provides instant support for Windows, NetWare, Unix, AppleTalk and Internet environments. Built-in wire-speed non-blocking switch fabric provides hardware-based packet filtering/forwarding. Packet routing is performed by on-board ASICs, which is many times faster than traditional CPU-based routers.
Seamless Integration
The DES-6300 can be instantly integrated into any existing network for seamless integration of multi-layer packet switching. With multi-layer support for every port, you can flexibly segment the network into domains and sub-domains, using (1) subnet, user and server IDs to route traffic, and (2) custom filters based on users' physical MAC addresses to filter extraneous traffic. At Layer 2, the switch uses auto-learned and user-defined MAC addresses to discard and forward packets. At higher layers, it looks at the routing table to route packets to their destinations.
Scalable Port Density
With a modularized design and a wide range of port selection from Ethernet/Fast Ethernet to twisted-pair and fiber Gigabit, this switch provides for easy, scalable expansion. Bandwidth migration is simple with 10/100/1000Mbps multi-speed support and module hot swapping capability. This architecture provides for great flexibility and investment protection.
Up to 96 Fast Ethernet or 12 Gigabit Ports
You can configure the switch with up to 96 10/100Mbps Fast Ethernet ports, 72 100Mbps fiber ports, 12 Gigabit ports, or a combination of these. Copper and fiber Gigabit ports (SX, LX and GBIC included) are provided. This flexible configuration allows you to install Fast Ethernet for workstation connections, copper Gigabit for departmental server connections, and fiber Gigabit for backbone/campus attachments.
Maximum Network Uptime
The switch provides the capability to operate with an optional redundant power supply. This gives you the added reliability against power interruption risks and is important for mission-critical applications. The switch comes standard with a single power supply. For campus/enterprise application, you can opt to install dual power supplies.
VLANs for Performance & Security
When operating at Layer 2, you can set up VLANs for different portsor users to set broadcast domains and segment network traffic to manage available bandwidths and enhance network security.
Port Trunks for Bandwidth Aggregation
You can combine up to 8 Fast Ethernet ports on the same module into a trunk to create a 1600Mbps full duplex aggregated bandwidth to connect to a server or to another switch. 2 Gigabit ports from the same module can be combined into to create a 4000Mbps trunk. Port trunking supports load-sharing and redundant backup links, and is useful for switch-to-switch cascading or server connection.
Quality of Service (QoS)
With Quality of Service based on multi-layer information, your workstations and server can be attached to the switch and run delay-sensitive applications like video-conference and IP telephony based on traffic prioritization and queuing mechanism.
IP Multicast (IGMP snooping)
The switch listens to IGMP (Internet Group Management Protocol) messages to build mapping table and associate forwarding filters. It uses GMRP (GARP Multicast Registration Protocol) to dynamically configure the switch ports to forward IP multicast traffic only to those ports associated with multicast hosts.
Port Mirroring
This capability allows you to mirror adjacent ports for the purpose of analyzing incoming and outgoing packets where packets can be studied.
General features
Topology
Star
Protocol
CSMA/CD
Data Transfer Rates
- Ethernet: 10Mbps (half duplex)
20Mbps (full duplex)
- Fast Ethernet:
100Mbps (half duplex)
200Mbps (full duplex)
- Gigabit Ethernet:
2000Mbps (full duplex)
Chassis
- Number of slots: 7
- Number of user-configurable slots: 6
- 2 redundant power supply bays
- Backplane switch fabric bandwidth: 32Gbps
Software (Embedded Firmware)
VLAN (Layer 2)
- IEEE 802.1Q VLAN Tagging
- Port-based VLANs: 4K per VLAN
- GARP/GVRP
Spanning Tree (Layer 2)
- Standards:
IEEE 802.1D Bridging STP (Spanning Tree Protocol)
IEEE 802.1w Rapid Spanning Tree - Spanning Tree per VLAN
- Root Avoidance (ability to block the switch from becoming STP Root)
- 802.1w Rapid Spanning Tree (edge port support)
- 802.1s Multiple Spanning Tree Groups (proprietary)
IP Routing (Layer 3)
- IP forwarding enable/disable
- IP Proxy ARP
- IP Fragmentation support
- IP v4 support
- IP multi-netting
- Path MTU discovery
- VRRP support
- Routing protocols: RIP-1, RIP-2, OSPF v.2
IPX Routing (Layer 3)
Routing protocol: IPX-RIP
Apple Talk Routing (Layer 3)
Bridge support only
(Classification & Prioritization)
- Layer 2:
Priority bits (IEEE 802.1p standard)
- Layer 3:
IP TOS and DSCP bits
IP destination & source addresses
- Layer 4:
TCP/UDP port number
Socket number
QoS (Others)
- Number of priorities queues: 4 per port
- Rate limit: physical port starting at 512Kbps
- Bandwidth control
- Broadcast storm control
Multicast
- GMRP
- IGMP v2
- IGMP Snooping
- PIM Dense mode
- PIM Sparse mode *
- DVMRP
Security (Layer 2 Filters)
- MAC based: user-specified MAC addresses
- VLAN based: ingress checking enable/disable
- Port based: MAC address learning per port enable/disable
Security (Layer 3 Access Control List)
IP address based
Access Control
IEEE 802.1x Port-based Network Access Control
Link Aggregation (Port Trunking)
- Standard: 802.3ad
- Ether Channel interoperable
- 802.3ad compatible link aggregation
- Number of port trunks: 16 per device
- Number of ports per Ethernet/Fast Ethernet trunk: 8 ports
- Number of ports per Gigabit trunk: 2 ports
Queuing Mechanism
- WRR or Weighted RED
- Strict Priority Queuing
Bandwidth Reservation
Resource Reservation Protocol (RSVP) *
Configuration & Management
Configuration
- RS-232 port out-of-band configuration
- Web-based
- Telnet server
- TFTP client
- Bootp client
- DHCP client
- DHCP/Bootp relay agent
Management
- Password enabled
- IP filtering on management interface
- NMS
- SNMP v1
- SNMP v.2c *
- TFTP firmware upgradeable
- SLIP/PPP for remote management
- CLI (Command Line Interface)
Management Agent
Supported protocols: IP, UDP , ARP , ICMP
MIB
- SNMP (RFC 1157)
- SNMP v.2 (RFC 1907)
- MIB II (RFC 1213)
- Bridge (RFC 1493)
- RMON (RFC 1757, 1271)
- Ethernet (RFC 1643)
- IP Forwarding Table (RFC 2096)
- RIP-1 (RFC 1058)
- RIP-2 (RFC 1723)
- OSPF (RFC 2178)
- CIDR (RFC 2096)
- 802.1p (RFC 2674)
- Private MIB (proprietary)
RMON
4 Groups: Statistics, History, Alarms, Events
Port Configuration & Monitoring
- Auto-negotiation
- Port Mirroring
Redundant Power Management
Power alarm
Performance
Switching Method (Layer 2)
- Store-and-forward
MAC Address Table (Layer 2)
- 64K entries per device
Auto MAC Address Learning
Address aging: 300 sec. (max.)
Routing Tables
- IPv4: 64K entries
- IPX: 32K entries
Packet Buffer Memory
16MB per module
Certificates
Order info
Multi-layer Routing Switch Chassis
DES-6300 Basic configuration (includes chassis + DES-6301 backplane +
DES-6302 management module + 1 DES-6310 power supply)
Optional Modules
DES-6303 16 10/100Mbps copper twisted-pair ports
DES-6304 12 100BASE-FX fiber ports (MT-RJ connectors)
DES-6305 8 100BASE-FX fiber ports (SC connectors)
DES-6306 2 1000BASE-SX Gigabit fiber ports (SC connectors)
DES-6307 2 1000BASE-LX Gigabit fiber ports (SC connectors)
DES-6308 2 10/100/1000Mbps Gigabit copper twisted-pair ports
DES-6309 2 Port GBICmodule
DES-6310 Universal redundant power supply (see specifications above)
