DNS-6040MEOL EOS
Description
Alternative to Traditional File Servers
Supporting up to 480GB hard disk capacity, the DNS-6040 series is an ideal alternative to deploying a traditional large capacity file server. It delivers hardware reliability plus compatibility with every major operating system and protocol. The DNS-6040 series can be deployed at a fraction of the cost of a complex traditional file server.
4 Reliable Hard Disk Bays
The DNS-6040 series provides 4 bays supporting 4 hard disks with RAID level 0, 1, 5 and 5 with hot spare. Equipped with hot-swappable IDE hard disk drives, this system gives you the availability and reliability required for today's Network Attached Storage. On-line re-build and testing report are provided.
Cost Saving
The DNS-6040 series comes with embedded software that provides ready file access for Windows, NetWare, Macintosh and Unix/Linux clients. This saves you the cost of buying separate O.S. software and the trouble of installing it in your server. Transparent multi-platform file sharing is easily accessible at system power-on.
Space Saving
The DNS-6040 series uses an innovative mechanical and electrical design to provide high-density disk storage for space-sensitive environments. With just a 1U height, the DNS-6040 series is ideal for deployment in data centers. Its slim profile lets you easily stack servers in a standard equipment rack to a maximum number of units.
Easy Installation
Installation is quick, easy and requires no network downtime. You simply plug in the power, connect the network cable and turn on the system power.
A single 250W internal universal power supply is provided as a standard feature. To maximize network uptime, you can configure the system with an additional 250W internal universal power supplies for redundancy power backup.
