Quick find
Product features:
GPON ONT Wireless N Gigabit VoIP Gateway
Description:
The DPN-R5402 GPON ONT Wireless N Gigabit VoIP Gateway is a GPON (Gigabit-capable Passive Optical Network) ONT (Optical Network Terminal) device that provides a Gigabit connection and voice features for indoor environments such as small offices and multi-unit buildings. GPON technology delivers up to 2.4Gbps speeds over optical fiber wiring, and
enables next-generation simultaneous voice, video, and data services including high-speed Internet access, video streaming, and instant messaging. It has a built-in 802.11n wireless interface and four LAN ports, so family members can connect to the network wirelessly, or through network cables. The DPN-R5402 is an effective, easy-to-deploy technology that can be used as a high-performance Internet solution.
Leverage Your Fiber
The DPN-R5402 GPON ONT Wireless N Gigabit VoIP Gateway provides an optical line connection to a GPON OLT on the CO side, multiple VoIP phone connections, an 802.11n wireless interface, two USB ports, and four 10/100/1000Mbps Gigabit Ethernet connections to the end-user’s LAN side. It utilizes the extraordinary bandwidth of GPON technology, the next step in the delivery of new high-speed Internet applications to home and office users. Designed for deployment inside a home or an apartment building, this ONT device provides a reliable, long-reach last-mile connection by extending the public high-bandwidth network to people living and working in remote multi-unit, multi-tenant buildings.
Secure Wired and Wireless Connections
The DPN-R5402 provides an integrated 802.11n WLAN that supports wireless speeds of up to 300Mbps and four Gigabit Ethernet ports for connecting to non-wireless computers and other network devices via network cables. To secure your wireless connections, this gateway provides the latest WPA/WPA2 security encryption protocols to maximize security, while also allowing WEP-secured connections for maximum compatibility with legacy devices.
Products | Support  | News  | About |
