DCS-6517Project
5 Megapixel Day & Night Outdoor Dome Network Camera
Where to buy
Description
The D-Link DCS-6517 5 Megapixel Day & Night Outdoor Dome Network Camera is a high definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera uses a 5 megapixel progressive scan CMOS sensor to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for additional accessories.
Built for the Outdoors
Specially built for outdoor use, the DCS-6517 has an IP66 weatherproof housing that protects it from dirt and rain. The durable housing of the DCS-6517 has also been designed to meet IK10 vandal proof specifications, meaning that it can be deployed into areas that require the peace of mind that the DCS-6517 can provide. Combined with its power over Ethernet (PoE) capability, the DCS-6517 truly is a versatile solution that be used in a wide range of applications.
Continuous Monitoring
In low-light situations, the IR cut filter automatically slides out of the way to use all availablelight. The DCS-6517 also has built-in IR LED illuminators with a 20 meter range, allowing the camera to keep watch even in complete darkness. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day. To maximize bandwidth efficiency and improve image quality, the DCS-6517 provides real-time video compression using the H.264, and MJPEG codecs, and supports three separate profiles for simultaneous video streaming and recording. This versatility enables a wide variety of security applications, such as monitoring public areas to detect incidents and to coordinate responses, enforcing access control to restricted areas, deterring criminal activity, or monitoring inventory.
Flexible Connectivity
The DCS-6517 has a built-in 802.3af compliant PoE module that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the included digital input and output connector enables connections to external devices such as IR sensors, switches and alarm relays.
Robust Management Software
The DCS-6517 5 Megapixel Day & Night Outdoor Dome Network Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
General features
Camera Hardware Profile
1/3.2” 5 Megapixel CMOS sensor
20 meter IR illumination distance
Built-in Infrared-Cut Removable (ICR) Filter module
Minimum illumination:
0.5 Lux Color mode
0.1 Lux Black and White mode
0 Lux Black and White mode with IR LED on
Minimum object distance 0.3 m
3 ~ 10.5 mm DC iris vari-focal lens
Aperture F1.4
Angle of view
   • (H) 25.48° to 85.03°
   • (V) 19.09° to 65.47°
Shutter Speed: 1/2.5 ~ 1/10,000
4x Digital zoom
Camera Housing
IP66 compliant weatherproof housing
IK-10 compliant vandal-proof housing
Included sunshield
Image Features
Configurable image size, quality, frame rate, and bit rate
Time stamp and text overlays
3 Configurable motion detection windows
Tamper detection
Configurable privacy mask zones
Configurable exposure, brightness, saturation, contrast, sharpness, white balance, WDR, flip and mirror
Video Compression
Simultaneous H.264/MJPEG format compression
H.264 multicast streaming
JPEG for still images
Video Resolution
16:9 - 1920x1080, 1280x720, 960 x 540, 640 x 360 at up to 30 fps
4:3 - 2560x1920, 2048x1536, 1600x1200, 1280x960, 800 x 600, 640 x 480, 320 x 240 at up to 15 fps
Audio Support
AAC
G.711
External Device Interfaces
10/100 BASE-TX Ethernet port with PoE
1 DI / 1 DO
Reset button
Video Out (BNC)
microSD card Slot (SD/SDHC)
Audio input / output
Network Protocols
IPv6
IPv4
TCP/IP
UDP
ICMP
DHCP client
NTP client (D-Link)
DNS client
DDNS client (D-Link)
SMTP client
FTP client
HTTP / HTTPS
Samba client
PPPoE
UPnP port forwarding
RTP / RTSP/ RTCP
IP filtering
QoS
CoS
Multicast
ONVIF compliant
SNMP
Security
Administrator and user group protection
Remote client access control
HTTP and RTSP authentication
HTTPS encryption for web access
System Requirements for Web Interface
Browser: Internet Explorer 7 or higher, Firefox, Chrome, Safari
Event Management
Motion detection
Event notification and uploading of snapshots/video clips via e-mail or FTP
Supports multiple HTTP, SMTP, and FTP servers
Multiple event notifications
Multiple recording methods for easy backup
Remote Management
Take snapshots/video clips and save to local hard drive
Configuration interface accessible via web browser
OS Support
Operating System: Windows 7/8/XP/Vista/2000
D-ViewCamTM System Requirements
Web Browser: Internet Explorer 7 or higher
Protocol: Standard TCP/IP
D-ViewCamTM Software Functions
Remote management/control of up to 32 cameras
Supports all management functions provided in web interface
Viewing of up to 32 cameras on one screen
Scheduled motion triggered, or manual recording options
Weight
1.25 kg
Power
Input: 12 V DC 1.5 A. 50/60 Hz, IEEE 802.3af PoE Class 0
Power Consumption
Max:11.6 W (PoE, heater on)
Temperature
Operating: -40 to 50  ̊C
Storage: -20 to 70  ̊C
Humidity
Operating: 20% to 90% non-condensing
Storage: 5% to 95% non-condensing
Certifications
CE
CE LVD
FCC
C-Tick
Certificates
Order info
Pictures
DCS-6517
Вид справа
Вид сзади
Вид сзади
Downloads
Support Resources
