DCS-8000LH
Mini HD Wi-Fi Camera
Description
The DCS-8000LH Mini HD Wi-Fi Camera is a compact wireless network camera suitable for day and night time environments. It features built-in night vision, motion and sound detection, and a free mobile app — so you can feel at ease when you’re away from home.
Compact Design, Simple Setup
The DCS-8000LH is designed to be compact and inconspicuous, so it can fit in with any decor no matter where you put it. Setting up the camera is also a breeze with the free mydlink Lite app and Bluetooth 4.0. To get started, simply install the app** on your mobile device and with a few taps the app will guide you through the entire setup process.
Versatile Feature Set
Despite its small size, the DCS-8000LH has all the features you need for monitoring your home. Onboard Wi-Fi provides extended range and higher bandwidth while still staying compatible with older wireless devices — for smoother 720p HD video streams on any device. Built-in motion and sound detection will automatically send alert notifications to your mobile device. Night-time monitoring is possible with the built-in infrared LED which allows for night-time viewing of up to 16 feet, so you can relax knowing you have 24/7 monitoring of your home or small office*.
Access Anywhere Using the Mobile App
With the mydlink app and website, you have an easy and convenient way for you to look after your family or to monitor your home or office. Stay up-to-date with notifications and check in on those you love at any time. Access your camera using the mydlink Lite mobile app and you can view and manage your camera using your mobile device. Enjoy instant control over your home surveillance with the ability to manually trigger video recording, no matter where you are.
*Use of audio or video equipment for recording the image or audio of a person without their knowledge and consent is prohibited in certain states or jurisdictions. The end-user assumes all liability for compliance with applicable state, local and federal laws
**The DCS-8000LH is not supported by the mydlink Home app and is not compatible with D-Link’s Connected Home Series.
General features
Hardware Profile
• 1/4” progressive CMOS sensor
• Minimum illumination: 0 lux with IR LEDs on
• Minimum object distance: 50 cm
• Lens focal length: 2.39 mm
• Aperture: F2.4
• Digital zoom (4x)
• 16 feet IR illumination distance
• Angle of view (16:9):
  - Horizontal: 112°
  - Vertical: 54°
  - Diagonal: 120°
• Built-in Infrared-Cut Removable (ICR) Filter
• Built-in microphone
Image Features
• Time stamp and text overlays
• Configurable sound detection level
• Configurable motion detection windows
Video Compression
• H.264 format compression
• JPEG for still images
Video Resolution
• 1280 x 720 at up to 30 fps
Audio Support
• PCM
Connectivity
• 2.4 GHz: 802.11n/g wireless with WPA/WPA2 encryption
Network Protocols
• IPv4, ARP, TCP, UDP, ICMP
• NTP client (D-Link)
• DNS client
• Bonjour
Event Management
• Motion detection
• Sound detection
• Manually taken snapshots & video clips are saved to mobile device
Mobile Support
• mydlink Lite and mydlink Plus apps for iPhone, iPad, iPod touch, and Android devices*
System requirements for mydlink Portal Web Management
• Please check your regional www.mydlink.com website for the most up-to-date requirements
Environment
• For Indoor Use Only
Weight
• 57.7 grams ± 5%
Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 5 V DC 1 A (Micro-USB)
Power Consumption
• Maximum: 4 watts ± 5%
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 70 °C
Humidity
• Operating: 20% to 80% non-condensing
Certifications
• CE
• CE LVD
• ICES
• FCC
Dimensions (L x W x H)
• 37 x 38.1 x 95 mm
* Check device app store for OS requirements.
Certificates
Order info
