DCS-5610EOL EOS
PoE PTZ IP CAMERA
Description
POWERFUL SURVEILLANCE
IP surveillance systems are quickly gaining over conventional CCTV security cameras due to superior performance and low costs. The DCS-5610 now features a Sony VGA Progressive Scan CCD technology which provides exceptional picture quality. Use D-Link's SoC (system-on-chip) products to provide high quality real-time video compression in MPEG-4 and Motion JPEG formats. DCS-5610 supports simultaneous dual-streaming for live monitoring and recording. With a built-in Samba client for NAS, DCS-5610 IP camera does not need a direct connection to a PC or any other hardware or software to capture and transfer images.
WIRED PoE ACCESS
For effective surveillance in and around a building, this camera comes with a built-in 802.3af compliant Power Over Ethernet (PoE) module, which eases the installation process and also gives you the freedom to place the camera where it's needed. In addition, a 10/100BASE-TX Ethernet port is also provided for convenient connection to an Ethernet network or to a broadband Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
Equipped with a light sensitive lens, this camera is capable of capturing video in rooms with minimal lighting. It features a motorized pan/tilt capability, allowing images to be monitored from different angles, and an optical zoom for greater remote viewing options. The DCS-5610 provides high quality real-time videos in MPEG-4 and JPEG compression with VGA/QVGA/QQVGA resolution delivering 30 frames per second, including the transmission of audio data. DCS-5610 supports Netscape, Mozilla and Opera browser (QuickTime for MPEG4 stream).
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE2
The live camera feed of the camera can be pulled from the 3G cellular network by using a compatible cell phone or PDA with a 3G video player. Anywhere within the 3GPP service area, users are offered a flexible and convenient way to remotely monitor a home or office in real time.
SMART & EASY TO USE
Records images 24 hours a day, 7 days a week to a computer’s hard drive only when motions are detected. This saves disk space and eliminates the time wasted to view unnecessary images. Also, images can be recorded manually or according to a pre-set schedule. Playback consumes little time with triggered event browsing and fast database searching. The software, D-View Cam allows you to view up to 32 cameras on a single computer screen at one central location. Users can set up automated e-mail alerts to be instantly informed of unusual activities. The camera supports the Universal Plug-n-Play feature, which allows computers running on Windows XP/ME/Vista to automatically recognize the camera and adds it to the network. Sign up with one of the free Dynamic DNS services available on the web, to assign a name and domain to the camera (e.g. mycamera.dlinkddns.com). This allows users to remotely access the camera without having to remember the IP address.
General features
NETWORK PROTOCOL SUPPORT
+ TCP/IP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, ICMP, Samba client
BUILT-IN NETWORK INTERFACES
+ 10/100BASE-TX Ethernet port
VIDEO ALGORITHM SUPPORT
+ JPEG for still image
+ Enhanced video compression using MPEG4 Simple Profile
+ MPEG4/MJPEG dual format compression
VIDEO RESOLUTION
+ Up to 30fps at 176 x 144
+ Up to 30fps at 320 x 240
+ Up to 30fps at 640 x 480
VIDEO FEATURES
+ Adjustable image size and quality
+ Time stamp and text overlays
+ 3 configurable motion detection windows
+ Flip & mirror
VIDEO BIT RATE
+ 20K to 4M
CAMERA SPECIFICATIONS
+ Sony Progressive Color CCD Sensor
+ 1 Lux @ F1.9
+ AGC/AWB/AES
+ Electronic shutter: 1/60 to 1/15000 sec.
+ Lens: 2.8~7.3mm, F1.9~200
+ 35.8˚~92.2˚ field of view
PAN/TILT/ZOOM
+ Pan range: +/- 150˚
+ Tilt Range: +90˚ to -45˚
+ Optical Zoom: 2.6x
+ Digital zoom: 4x
LAN
+ IEEE 802.3 compliance
+ i EEE 802.3u compliance
+ Support Full-Duplex operations
+ 802.3x Flow Control support for Full-Duplex mode
+ Supported IEEE 802.3af standard (PoE)
PHYSICAL & ENVIRONMENTAL
DIAGNOSTIC LED
2 color LED
POWER INPUT
+ 12VDC 1.5A
+ Through 100 to 240 VAC 50/60Hz 0.4A external power adapter
POWER CONSUMPTION
6W
DIMENSIONS (mm)
104(H) X 103.5 (W) X 118 (D)
WEIGHT
319 gm
AUDIO
+ GSM-AMR/MPEG-4 AAC
+ Supports Audio mute
MICROPHONE
+ Directivity: omni-directional
+ Frequency:50 to 16000Hz
+ S/N ratio: more than 58dB
SECURITY
+ Administrator and user group protected
+ Password authentication
SURVEILLANCE SOFTWARE FUNCTIONS
+ Remote management/control of up to 32 cameras
+ Viewing of up to 32 cameras on one screen
+ Supports all management functions provided in web interface
+ Scheduled motion triggered, or manual recording options
REMOTE MANAGEMENT
+ Configuration accessible via web browser
+ Take snapshots/video clips and save to local hard drive or
remote server via web browser
SURVEILLANCE
(Motion detection weekly schedule)
+ Upload snapshots/video clips via email
+ Upload snapshots/video clips via FTP
SYSTEM REQUIREMENTS
+ Operating System: Microsoft Windows 2000, XP, Vista
+ Browser: Internet Explorer, Firefox, Netscape, Mozilla, Opera browser
SUPPORTED PDA, MOBILE PHONES & SOFTWARE
+ Handsets with 3GPP player
+ Packet Video Player 3.0
+ QuickTime 6.5
+ Real Player 10.5
+ Windows 2000, XP
OPERATION TEMPERATURE
0º to 40º C (32º to 104º F)
STORAGE TEMPERATURE
-20º to 70º C (-4º to 158º F)
HUMIDITY
20% to 80% non-condensing
EMISSION (EMI), SAFETY & OTHER CERTIFICATIONS
+ FCC Class B
+ CE
+ C-Tick
PACKAGE INCLUDES
+ DCS-5610 camera
+ External power adapter
+ Cat. 5 Ethernet cable
+ Quick Installation Guide
+ Master CD
+ Camera stand
Certificates
Order info
Pictures
DCS-5610
Front view
Downloads
Support Resources
