DCS-25EOL EOS
Description
D-Link’s SecuriCam IP Camera accessories provide cost-effective solutions for the diversity of application. The DCS-10 IR illuminator and DCS-20 IR lens can be used for both day and night surveillance, and the DCS-25 vari-focal CS lens provides easy installation without the need to change lenses for particular applications. Protect your home and business by maximizing the full potential of D-Link’s IP cameras and these benefcial accessories.
The DCS-25 is a CS mount vari-focal auto iris lens for 1/3” and 1/4” sensors with IR correction.
General features
Supported Devices
- DCS-3410
- DCS-3420
Dimensions
36 (Ø) x 52.3 (D) mm (1.42 x 2.06 inches)
Weight
90 g (0.2 lbs)
Focal Length
F3.5-8.0 mm / F1.4-360
Iris / Focus Control
- DC drive
- Manual focus
View Angle
95-42 degrees
