DUB-1310EOL EOS
2-Port USB 3.0 PCI Express Card
Where to buy
Description
BlazIng USB 3.0 speed
Connect your PC to USB 3.0 devices at blazing speeds of up to 5 Gbps - up to 10 times faster than USB 2.0. You can back up your photos, music, and HD movies to an external storage device faster than ever before.
Plug and Play connectivity
Just insert the card into an available PCI Express x1 slot and run the Setup Cd to add 2 USB 3.0 ports to your PC.
Connect all your peripherals
Backward compatibility with USB 2.0 and USB 1.1 mean that you can connect any USB device to the dUB-1310. If you need more ports, you can connect additional USB hubs to connect up to 127 devices.
General features
Interface
• PCI Express x1
• 2 downstream USB type a (female) ports
Standards
• USB specification version 3.0
• USB specification version 2.0
• USB specification version 1.1 1
• USB specification version 1.0
•ƒ OHCI (open Host Controller Interface)
•ƒ EHCI (Enhanced Host Controller Interface)
•ƒ PCI Express 2.0
Data rates
•ƒ SuperSpeed: 4.8 Gbps
•ƒ High Speed: 480 Mbps
•ƒ Full Speed: 12 Mbps
•ƒ Low Speed: 1.5 Mbps
Connectivity
Up to 127 devices by cascading multiple hubs
System requirements
• Windows® 7/vista/XP SP3 or higher
•ƒ Available PCI Express x1 slot
Supplied power
Maximum 900ma per port
Dimensions (l x W x H)
75.8 x 61.5 x 2.0 mm (2.98 x 2.42 x 0.08 inches)
Weight
43 grams
Operating temperature
0 to 40 °C (32 to 104 °F)
Storage temperature
-20 to 60 °C (-4 to 140 °F)
Operating humidity
0% to 80% (non-condensing)
Package contents
• D-link 2-Port USB 3.0 PCI Express Card
• Full-height bracket
• Half-height bracket
Certifications
• USB-IF
•ƒ WHQL
•ƒ FCC
•ƒ CE
Certificates
Order info
DUB-1310  2-Port USB 3.0 PCI Express Card
Pictures
DUB-1310
Downloads
Support Resources
