DU-520EOL EOS
High Speed USB 2.0 5-Port PCI Adapter
Where to buy
Description
The Quickmedia DU-520 is a 5-port USB 2.0 PCI adapter that upgrades desktop computers to the new USB 2.0 standard. This card is designed to work with drives, webcams, and other USB enabled devices. At up to 40 times faster than USB adapters, the five USB 2.0 ports can transfer data at 480 Megabits per second*, making it ideal for external storage, backup, networking and video devices.
The DU-520 is backward compatible with USB 1.0 and USB 1.1 products. This gives you the ability to connect all of your USB 1.x devices to the DU-520 USB 2.0 adapter. Each port detects whether the connected device is USB 1.x or USB 2.0 and runs the device at the correct speed.
The DU-520 includes drivers for the most popular operating systems, including Microsoft Windows XP, 2000, Me, 98SE, and Macintosh OS X. And with easy to understand installation instructions, you can install and connect your USB devices quickly and easily.
* Maximum transfer rate based on USB 2.0 specifications. Actual data throughput will vary.
General features
Certificates
Order info
Pictures
DU-520
Вид справа
Downloads
Support Resources
