DUB-104EOL EOS
USB 2.0 POCKET HUB
Where to buy
Description
ADD 4 USB 2.0 PORTS TO YOUR COMPUTER
With the DUB-104 Universal Serial Bus (USB) 2.0 Pocket Hub, easily add USB ports to your computer. Now you can connect up to 4 more USB peripherals such as your  digital camera, printer, CD drive, mouse, and fash drive to your notebook computer.
SEAMLESS CONNECTION
The DUB-104 USB Pocket Hub is designed to provide quick and easy access to the 4 USB 2.0 ports. A dongle is provided to connect to the host computer or another USB hub. Confgured directly by the operating system, this USB Pocket Hub operates seamlessly with Microsoft’s OpenHCI, Intel’s Universal HCI, and USB 2.0’s latest specifcation, EHCI. The USB Pocket Hub supports computers operating Microsoft Windows or Apple Mac operating systems.
EASY TO USE
Connect this tiny USB Pocket Hub to an available USB port on your notebook computer and your installation is complete. It’s that simple. There are no power switches or buttons to press. This Pocket Hub will always be ready to go. Designed especially for PC and Mac notebook users, this device provides a simple, cost-effective USB connectivity solution for your USB peripherals.
SLIM-SIZED, LIGHTWEIGHT, TAKE IT WITH YOU, WHEREVER YOUR NOTEBOOK GOES
Through an attached USB cable, which can be neatly placed inside a built-in compartment, the Pocket Hub conveniently connects to your notebook PC. Designed to ft into any notebook bag, the compact size of the Pocket Hub will allow you to conveniently carry it with you wherever you go. Experience the ultimate in portability and expandability with the D-Link DUB-104 4-Port USB 2.0 Pocket Hub.
General features
Certificates
Order info
Pictures
DUB-104/Ax
Downloads
Support Resources
