Description
D-Link, the industry pioneer in networking, introduces the D-Link Structured Cabling Systems family of products. The cables are protected with PCV plastic that is strong but flexible enough to fit into tight working spaces. All the cables in this family conform to the highest standards and have been certified by UL laboratories.
D-Link's USB 2.0 cables are USB-IF certified to ensure that your USB devices will work and operate at the fastest speed possible. USB 2.0 extends the speed of the peripheral-to-PC connection up to 480Mbps* - 40 times faster than USB 1.1 when connected to another USB 2.0 device. The USB 2.0 cables can also be used to connect legacy USB 1.1 devices. The higher bandwidth supports applications such as digital image creation and web publishing, where multiple high-speed peripherals run simultaneously.
