Quick find
Old model
Product features:
WIRELESS G ACCESS POINT
Description:
CONNECT HOME USERS TO A WIRELESS NETWORK
Create a wireless network for your home using the D-Link DAP-1150, Connect this 802.11g standard Wireless Access Point a broadband modem and wirelessly share your Internet connection. Enjoy surfing the web, checking e-mail, and chatting with family and friends online.
PROTECT WIRELESS NETWORK AND DATA
The DAP-1150 provides 64/128-bit WEP encryption and WPA/WPA2 security to protect your network and wireless data. In addition, it also provides MAC address filtering and the Disable SSID Broadcast function to limit outsiders’ access to your wireless network.
FLEXIBLY CONFIGURE YOUR AP FOR DIFFERENT APPLICATIONS
The DAP-1150 can be configured to operate as an Access Point to act as a central hub for wireless users, a Wireless Client to connect to a game console, or a Repeater to extend the wireless coverage to cover “dead” spots. These flexible operations allow you to use your DAP-1150 for different purposes.
EASY TO INSTALL AND USE
With D-Link Setup Wizard, you can set up your wireless network in minutes. It configures your DAP-1150, makes it easy to add new wireless devices onto the network, and helps you create a simple wireless network for your home. A slide switch is provided on the back for users to select an operation mode. In addition, the DAP-1150 is Wi-Fi Protected Setup™ (WPS) certified, making it even easier to configure your wireless network and enable security.
Products | Support  | News  | About
