Quick find
Product features:
Wireless N300 Dual Band Access Point/Bridge
Description:
Fast, reliable connections to your devices
The D-link Wi-Fi Booster allows you to create reliable, high-speed connections to your wired and wireless devices. It features dual-band 802.11n wireless with D-link’s Smart Beam technology, and allows you to choose either the 2.4GHz wireless band for compatibility, or the 5GHz wireless band for interference free connections with compatible devices. The Wi-Fi Booster also includes four gigabit LAN ports with easy to use port-based Quality of service (QoS); simply plug in your wired devices in order of importance, and the Wi-Fi Booster will automatically configure QoS for you. You can even connect a USB printer or storage drive and share it through D-link’s SharePort feature.
By using D-link’s unique smart Antenna design, the Wi-Fi Booster automatically adjusts its coverage to provide an optimized connection for each authorized wireless client. This extends coverage, minimizes interference, provides higher wireless speeds, and even helps to save energy by adjusting the amount of power used for wireless connections.
Double the wireless coverage
The Wi-Fi Booster’s multiple antenna design gives you double the wireless coverage when compared to a standard antenna, eliminating dead spots.
Connect your devices from farther away than ever before, and enjoy a solid connection to your network, inside, outside, and around your house, even across different floors.
Stay safe and secure
Prevent unauthorized access to your network with WPA/WPA2 wireless encryption, which keeps your network traffic secure from prying eyes. You can also set up a Guest Zone to provide limited wireless access on a separate wireless network from your own devices, and wireless scheduling allows you to shut down your wireless network when you are away from your home or office.
Products | Support  | News  | About |
