Quick find
Product features:
Triple 2.4GHz Omni-Directional Antenna, 2dBi
Description:
Optimal Performance
Triple 2.4GHz omni-directional D-Link ANT24-0230 antenna is a universal antenna, designed to improve the performance of your Xtreme N adapter (DWA-552) and Router (DIR-655) from the D-Link company, as well as the RangeBooster N 650 Adapter (DWA- 547) and Router (DIR-635) from the D-Link company.
Indoor Installation
Triple 2.4GHz omni-directional D-Link ANT24-0230 antenna comes with an extension cable that allows you to place the antenna close to the adapter and the router. Thus, it is possible to have a functioning wireless network by placing a desktop computer under the table, and the antenna ANT24-0230 on the table, or attach it to the wall. You might also consider the location of the router in a closet or a confined space in which you can still achieve optimal wireless coverage by using a triple 2.4GHz omni-directional antenna.
Installation Flexibility and Increased Productivity
Triple 2.4GHz omni-directional D-Link ANT24-0230 antenna increases the flexibility of the plant for the adapter and the router, allowing you to increase network capacity.
Products | Support  | News  | About |
