Quick find
Product features:
Wireless N150 Access Point & Router
Description:
Wireless Interface
Using the DAP-1155 device, you are able to quickly create a wireless network and let your relatives or employees connect to it virtually anywhere (within the operational range of your wireless network). DAP-1155 can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 150Mbps).
The device supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, the “client” function, WPS, WMM.
Security
DAP-1155 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of DAP-1155 via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the device itself finds approved firmware on D-Link update server and notifies when ready to install it.
Products | Support  | News  | About |
