Quick find
Product features:
High Gain Directional Panel Antenna for 2.4 GHz ISM Band
Description:
D-Link®, an industry leader in networking, introduces the ANT24-1400 14 dBi Directional Panel Antenna designed to provide extended coverage for an existing 802.11b/g wireless network. The directional design of the ANT24-1400 offers dramatically increased wireless signal coverage in a specific direction allowing for improved data throughput at further distances.
The D-Link ANT24-1400 14dBi Directional Panel Antenna connects to a variety of wireless PCI adapters, wireless routers, and access points on the market today. Whether the wireless router or access point has a SMA or TNC connector, the ANT24-1400 comes with a RP-SMA to RP-TNC conversion adapter to accommodate either connector type.
The D-Link ANT24-0801 includes a swivel mount that allows pivotal adjustment for precise positioning for the most concentrated signal strength. The D-Link ANT24-1400 also includes a lightning surge protector, and a 0.5m (1.5 feet) cable. The ANT24-1400 is weatherproof and made of corrosion-resistant material to withstand harsh outdoor conditions and wind speeds up to 112 miles/hr (180km/hr).
Avoid the cost and complexity of adding additional wireless access points or wireless repeaters when you can easily use the ANT24-1400 indoors or outdoors. Enjoy the benefits of wireless connectivity at greater distances and speeds throughout your indoor or outdoor wireless coverage area.
Products | Support  | News  | About |
